def process_all_textures(**kwargs):
pre = kwargs.setdefault(‘prefix’, ‘my_’)
texture = kwargs.setdefault(‘texture_node’)
return cmds.rename(texture,’%s%s’% (pre, texture)
texture = process_all_textures(texture_node = texture)
print(texture)
print(texture)
missing a final end parenthesis
Thank you, you were right about the parenthesis.
Charcoal now says, error Line5: texture is not defined:
def process_all_textures( **kwargs):
return cmds.rename(texture,’%s%s’% (pre, texture))
print(texture)
It would be helpful if you post code with proper formatting
print(texture)
This makes it easier to notice that when you run process_all_textures on line five, you use [texture] as input, but it has not been defined in this example.
Yes. I am sorry. I hit send prematurely without formatting.
I will be more diligent next time. And thanks for the response.
This is a code snipet out of the book ‘Maya Python for Games and Film’
I’m just following along with the exercises.
So in other words, I need to have an actual texture loaded into maya
named ‘texture’ ?
yes you likely need a file node present, then give that file node path as the argument.
btw file node = node that samples a texture…strange naming in my opinion.
So if the file node is called my_texture, the input will be “|my_texture”
(can’t confirm because I currently don’t have a maya license)
I thought it looked familiar
The code which defines the texture variable is on page 67, section 5:
import maya.cmds
texture = maya.cmds.shadingNode('file',asTexture=True) # << here
process_all_textures(texture)
It creates a Maya shadingNode and assigns its name to the variable texture
The snippet you cite is from page 73 section 19, and it assumes that texture still exists as a defined variable which would only happen if you were doing these exercises one after the other in a single Maya session.
you probably need to combine sections:
import maya.cmds
pre = kwargs.setdefault('prefix', 'my_')
texture = kwargs.setdefault('texture_node')
return cmds.rename(texture,'%s%s' % (pre, texture))
texture = maya.cmds.shadingNode('file',asTexture=True) # define 'texture'
texture = process_all_textures(texture_node = texture) # process 'texture'
print(texture)
@ricgreen1 our code example uses non-ascii ‘curly quotes’ , watch out for that.
Oh, that is what I thought, Very good. Its working.
thanks again !
