I’m stuck on something that should be really obvious. I need to make a little window with some buttons that will export some fbx based on certain presets,
but for some reason, Maya refuses to do his job:
the first thing I tried was to load an external preset
preset_anim = "C:/Users/nsira/Dropbox/3D/MAYA/ExportUtility/FBX_presets/animations.fbxexportpreset"
# Load the preset from the file
preset = cmds.FBXLoadExportPresetFile(f=preset_anim )
# Export the selected objects as FBX using the preset
cmds.FBXExport(f=output_path, s=True, p=preset)
but I get this error:
# Error: RuntimeError: FBXLoadExportPresetFile: Error bad syntax.
# Use syntax: FBXLoadExportPresetFile -f "filepath"
after giving up on the external file I tried using a preset already in my collection, but even so, it doesn’t work
cmds.FBXExport(f=output_path, s=True, p="animations")
even in this case, I get this message:
# Error: RuntimeError: Use syntax: FBXExport -f "filename" [-s]
I’ve tried almost everything, even using the correspondent mel command but still doesn’t work.
Has somebody any idea on how to use this FBXExport command? I haven’t found any proper documentation.
