Hello, I think I am using this blog for the first time. I am a little excited. Now I have a problem that bothers me. I am a binding artist and work with Maya most of the time. Recently I am working on motionbuilder. Among them, rivet is in Maya. You can easily set a locator to the surface of the object to follow the movement. Max also has a similar attachment function, but I don’t know how to do it in motionbuilder. Do you have any good methods?
you can use a position/orientation constraint with the weights of the nearest influences to achieve that
yes,thanks。
This sounds like a method, but I want a more accurate method, similar to The Follicle in Maya and the attachment of 3DMax, which can accurately follow the movement of a certain point or point
It is accurate if you map the vertex influence weight to the constraint target weights it will follow exactly the skinned vertex. or you use a custom plugin like this https://www.youtube.com/watch?v=M0MGZV39G1c
Thanks for answering. In fact, it is not accurate if there is a morph directly to make the constraint. I am considering using the plug-in in your address to implement it, but can you talk about the principle of plug-in implementation, if I can explain it, I am really grateful, I need it too much Him
It is accurate for skinned meshs, if you are adding morphs then correct it won’t be accurate but like all things it depends on what you need.
For the plugin, all the information to install and use the plugin are on the page GitHub - Neill3d/OpenMoBu: Scripts and plugins for Autodesk MotionBuilder
Open MotionBuilder Rigging Tools - Rigging Dojo more tips on using his tools
OK, thank you very much
hello @bclark and @Munkybutt how do I get the
in python?
I’m trying to do the same thing, parent a locator or marker to a mesh surface. but I don’t want to use the OpenMobu plugin
I have never queried that info in mobu before but do know you can find the skin deformer which I would guess will contain the weight data.
This might help: Solved: Re: Getting weight table for each vertex in skinned model. - Autodesk Community
It’s in c++ but it should translate relatively easily
