I’m trying to figure out how to import and merge an animation fbx file into a referenced rig with a unique namespace. I can do it manually in the import options but I’m not sure how to do that through code.
Does anyone know the way to do this?
Ah I figured it out at least for merging an FBX files animation into a referenced rig
# Set the current namespace
cmds.namespace( set='Rig01' )
filepath = "D:/folder/filename.fbx"
if os.path.exists(filepath):
try:
cmds.file (filepath, i=True, type="FBX", ignoreVersion=False, renameAll=True, mergeNamespacesOnClash=False, namespace="", preserveReferences=True, importTimeRange="combine")
except Exception as e:
cmds.warning("Could not import: " + filepath + ";\n" + str(e))
This won’t work for a mayaBinary file however but at the very least I can merge the correct animations and create the animation layers after.
