Is there a way I can move a specific node based on the mouse/cursor’s positions?
I tried the setPosition or the move method but it doesn’t work. It also doesn’t error out.
Here’s my code so far:
new_node = con.createNode(node_name)
pos = QtGui.QCursor.pos()
new_pos = hou.Vector2(values=(pox.x(), pox.x()))
new_node.setPosition(new_pos)
new_node.move(new_pos)
May I ask what am I missing?
I have gotten the mouse position in a network pane using this code.
node.setPosition(
hou.ui.paneTabOfType(hou.paneTabType.NetworkEditor).cursorPosition()
Which i use in this function
def create_merge_node_at_mouse(**kwargs):
Create a merge node at your mouse position with whatever node is currently selected
:param kwargs:
:return:
try:
(node,) = hou.selectedNodes()
node.setColor(hou.Color(0.302, 0.525, 0.114))
parent = node.parent()
merge = parent.createNode('object_merge', '%s_MERGE' % node.name().upper())
merge.setPosition(
merge.parm('objpath1').set(merge.relativePathTo(node))
merge.setColor(hou.Color(0.475, 0.812, 0.204))
except Exception as e:
pass
Hi @csprance
Thanks for the response. Works as expected
