I am messing the insert edge loop tool, I would like to create variations of it for myself (simply activating the tool with different options pre-enabled)
The script editor tells me its Mel command name is SplitEdgeRingTool. Checking the docs to learn more about it and there is no match…
I tried using whatis:
whatIs SplitEdgeRingTool;
// Result: Run Time Command
//editMenuUpdate MayaWindow|mainEditMenu;
What is a “Run Time command”, also I thought all built in Mel commands were documented??
