Simple DDS loader
I was looking for a simple way to load DDS files in python.
I found this: http://pyffi.sourceforge.net/ (but I am using pythin 2.7 so I can’t use it, it requires python3) Has anyone used that, or have another way of easily dealing with DDS file loading/viewing?
I also noticed, that pyglet appears might have some ability to load DDS (I didn’t try this): https://github.com/agileperception/pyglet/blob/master/tools/ddsview.py
I found this reference here: Loading a DDS to a QImage using QGLPixelBuffer. · GitHub
For anyone else looking … I converted that to python (made it a simple class) that returns a QImage - Most tools, I am often displaying stuff in Pyside/PyQT anyway.
#!/usr/bin/env python
#coding:utf-8
#reference:  https://gist.github.com/bjorn/4635382
__author__ = 'jgalloway@bluepointgames.com'
# -- This line is 75 characters -------------------------------------------
# example code
#QImage readDDSFile(const QString &filename)
    #QGLWidget glWidget;
    #glWidget.makeCurrent();
    #GLuint texture = glWidget.bindTexture(filename);
    #if (!texture)
        #return QImage();
    #// Determine the size of the DDS image
    #GLint width, height;
    #glBindTexture(GL_TEXTURE_2D, texture);
    #glGetTexLevelParameteriv(GL_TEXTURE_2D, 0, GL_TEXTURE_WIDTH, &width);
    #glGetTexLevelParameteriv(GL_TEXTURE_2D, 0, GL_TEXTURE_HEIGHT, &height);
    #if (width == 0 || height == 0)
        #return QImage();
    #QGLPixelBuffer pbuffer(QSize(width, height), glWidget.format(), &glWidget);
    #if (!pbuffer.makeCurrent())
        #return QImage();
    #pbuffer.drawTexture(QRectF(-1, -1, 2, 2), texture);
    #return pbuffer.toImage();
#from PySide import QtGui, QtCore
import os, sys
from OpenGL.GL import *
#import numpy as np
from PySide.QtOpenGL import *
from PySide.QtGui import *
from PySide.QtCore import *
# global debug config set up in my tool setup
global gDebug
from bp_config.debugConfig import gDebug, setDebug
# my path convenience class, should be easy to remove/replace
from bp_files.bp_path import Path
## DDS file reader
class fileDDS(object):
    """This class represnts a generic DDS file as a QImage"""
    global gDebug
    # --BASE-METHODS-------------------------------------------------------
    # --constructor-
    def __init__(self, filePath=None):
        self._filePath = None
        self._width    = int(0)
        self._height   = int(0)
        self._qImage   = None
        if filePath != None:
            self._filePath = Path(filePath)
            self._qImage = self.readDDSFile(self._filePath)
    # --method-------------------------------------------------------------
    def readDDSFile(self, filePath=None):
        glWidget = QGLWidget()
        texture = glWidget.bindTexture(filePath)
        if not texture:
            return QImage()
        # Determine the size of the DDS image
        self._width =  glGetTexLevelParameteriv(GL_TEXTURE_2D, 0, GL_TEXTURE_WIDTH)
        self._height = glGetTexLevelParameteriv(GL_TEXTURE_2D, 0, GL_TEXTURE_HEIGHT)
        if gDebug:
            print 'Image W/H:: {0}, {1}'.format(self._width, self._height)
        if self._width == 0 and self._height == 0:
            return QImage()
        pbuffer = QGLPixelBuffer(QSize(self._width, self._height), glWidget.format())
        if not pbuffer.makeCurrent():
            return QImage()
# --call block-------------------------------------------------------------
if __name__ == "__main__":
    '''Allows the script to be run as main()'''
    global gDebug
    gDebug = setDebug(True)
    global myApp
    myApp = QApplication(sys.argv)
    myApp.setStyle('Plastique')
    testPath = Path(r'testDDS.dds')
    image = fileDDS(testPath)._qImage
    # Should get back a QImage
    print image
    sys.exit(myApp.exec_())
this page might provide some help.
Some more info for people looking:
Pyglet is not supported in the amd64 python… so it’s DDSImageDecoder won’t import.
I remembered that the kivy project added support for compressed textures, so I went and checked there. They do have a DDS module:
Using it to load my test DDS, I can get back this object: <DDSFile filename=Path(u’testdds.dds’) size=(512, 512) dxt=‘s3tc_dxt1’ len(images)=10>
So I do know it’s loading. Not sure yet how to get the image data back (or if I can)
Nice find! that is super useful and a great resource for reference.
I just stumbled across this today:
python bindings:
It looks like it supports DDS
