Hey guys!
I think this may actually be the first time I’ve posted something I’ve worked on! So I noticed my portfolio was really light on shader work. So today I whipped this up. I call it SemiToon!
It’s a bit inspired by TF2, and how it’s not quite traditionally Toon Shaded, but definitely Non-Photo-Real. At it’s heart, SemiToon takes traditional lighting calculations, and picks a place to clamp them, and fades between the clamped regions. These clamps produce a toon-like effect. If you set the ToonMinimum and ToonMaximum parameters to 0 and 1, respectively, you get something very close to a traditional Lambert/Phong. If you make the numbers very close together, you will get a hard-edge toon look. The awesome part is, if you really wanted to, you could dynamically change these parameters to make something change from non-toon to toon and back again before your very eyes. Ambient Color is masked to only areas that receive no light, so that you can get dynamic colored shadow effects. I didn’t put much love into the Lighting Accumulation ( 2 Points, just to prove that it works. ) because it seems that every Engine does it differently these days.
The shader comes in 3 flavors.
REALLY EXPENSIVE ( Transparent with an Outline )
Pretty Expensive ( Opaque with an Outline )
Spry ( Opaque, No Outline )
If you use the outline, you want to close out your pass for every group you want outlined. ( FX Composer will batch them all into one set of passes by default, so if you use that, the outlines might look funny when they overlap. )
The Toon Outline was a HUGE pain to get correct with no artifacts. I’ve never done that before. I just fumbled through a bunch of Stencil Tricks until it worked. How do you guys do things like that?
I’d love to hear what you guys think about SemiToon! I’d also really welcome critiques about coding style or things going on in the code. Tips and Tricks are welcome to! A lot of this Toon-Shading stuff is new ground for me, and I really just did it by feel.
// SemiToon: by Lithium
// Semantics
float4x4 WorldInverseTranspose : WorldInverseTranspose < string UIWidget="None"; >;
float4x4 WorldViewProject : WorldViewProjection < string UIWidget="None"; >;
float4x4 ViewProject : ViewProjection < string UIWidget="None"; >;
float4x4 World : World < string UIWidget="None"; >;
float4x4 ViewInverse : ViewInverse < string UIWidget="None"; >;
// Parameters
// Frame
float3 AmbientLight : Ambient <
string UIName = "Ambient Lighting";
string UIWidget = "Color";
> = {0.1f, 0.1f, 0.1f};
// Bound
bool UsePoint0
string UIName = "Use Point Light 0";
> = true;
float3 Point0Pos : POSITION
string Object = "Point Light 0";
string UIName = "Lamp 0 Position";
string Space = "World";
> = {0.5f,2.0f,1.25f};
float3 Point0Col : COLOR <
string UIName = "Lamp 0 Color";
> = {1.0f,1.0f,1.0f};
float Point0Constant : CONSTANTATTENUATION <
string UIName = "Lamp 0 Constant Attenuation";
string UIWidget ="slider";
> = 1;
float Point0Linear : LINEARATTENUATION <
string UIName = "Lamp 0 Linear Attenuation";
> = 0.05;
float Point0Quadratic : QUADRATICATTENUATION <
> = 0;
bool UsePoint1
string UIName = "Use Point Light 1";
> = true;
float3 Point1Pos : POSITION
string Object = "Point Light 1";
string UIName = "Lamp 1 Position";
float3 Point1Col : COLOR <
string UIName = "Lamp 1 Color";
> = {1.0f,1.0f,1.0f};
float Point1Constant : CONSTANTATTENUATION <
string UIName = "Lamp 1 Constant Attenuation";
> = 1;
float Point1Linear : LINEARATTENUATION <
string UIName = "Lamp 1 Linear Attenuation";
> = 0.05;
float Point1Quadratic : QUADRATICATTENUATION <
> = 0;
// Vertex Properties
float BorderThickness <
string UIName = "Border Thickness";
string UIWidget = "slider";
float UIMin = 0.0f;
float UIMax = 10.0f;
float UIStep = .01f;
> = .05f;
float4 BorderColor <
string UIName = "Border Color";
> = { 0, 0, 0, 1 };
// Surface Properties
float4 DiffuseColor : DIFFUSE <
string UIName = "Diffuse Color";
> = {0.5f, 0.5f, 0.5f, .1f};
texture DiffuseMap <
string ResourceName = "";
string UIName = "Diffuse Texture";
string ResourceType = "2D";
sampler2D DiffuseMapSampler = sampler_state {
Texture = <DiffuseMap>;
MinFilter = Linear;
MagFilter = Linear;
MipFilter = Linear;
AddressU = Wrap;
AddressV = Wrap;
float DiffuseToonMin <
string UIName = "Toon Diffuse Minimum";
float UIMin = 0.0f;
float UIMax = 1.0f;
> = 0.1f;
float DiffuseToonMax <
string UIName = "Toon Diffuse Maximum";
float UIMin = 0.0f;
float UIMax = 1.0f;
> = 0.25f;
texture NormalMap <
string UIName = "Normal Texture";
sampler2D NormalMapSampler = sampler_state {
Texture = <NormalMap>;
MinFilter = Linear;
MagFilter = Linear;
MipFilter = Linear;
AddressU = Wrap;
AddressV = Wrap;
// Specular
float3 SpecularColor : SPECULAR <
string UIName = "Specular Color";
> = {0.8, 0.8f, 1.0f};
texture SpecularMap <
string UIName = "Specular Texture";
sampler2D SpecularMapSampler = sampler_state {
Texture = <SpecularMap>;
MinFilter = Linear;
MagFilter = Linear;
MipFilter = Linear;
AddressU = Wrap;
AddressV = Wrap;
float SpecularIntensity <
float UIMin = 0.0;
float UIMax = 1.0;
float UIStep = 0.01;
string UIName = "Specular Intensity";
> = 0.5;
float SpecularPower : SpecularPower <
float UIMin = 1.0;
float UIMax = 128.0;
float UIStep = 1.0;
string UIName = "Specular Power";
> = 5.0;
float SpecularToonMin <
string UIName = "Toon Specular Minimum";
float UIMin = 0.0f;
float UIMax = 1.0f;
float UIStep = .5;
> = 0.5f;
float SpecularToonMax <
string UIName = "Toon Specular Maximum";
float UIMin = 0.0f;
float UIMax = 1.0f;
float UIStep = .65f;
> = 0.55f;
// Interop
struct appdata
float3 Position : POSITION;
float4 UV : TEXCOORD0;
float4 Normal : NORMAL0;
float4 Tangent : TANGENT0;
float4 Binormal : BINORMAL0;
struct vertexOutput
float4 HPos : POSITION;
float2 UV : TEXCOORD0;
float3 Normal : TEXCOORD1;
float3 Tangent : TEXCOORD2;
float3 Binormal : TEXCOORD3;
float3 Eye : TEXCOORD4;
float3 Light0 : TEXCOORD5;
float3 Light1 : TEXCOORD6;
// VERTEX
vertexOutput SemiToonVS( appdata IN )
vertexOutput OUT;
// Pass Through
OUT.UV = float2( IN.UV.x, 1 - IN.UV.y );
// World Space
OUT.Normal = mul(IN.Normal, WorldInverseTranspose ).xyz;
OUT.Tangent = mul(IN.Tangent, WorldInverseTranspose ).xyz;
OUT.Binormal = mul(IN.Binormal, WorldInverseTranspose ).xyz;
float4 MPos = float4( IN.Position.xyz, 1 );
float4 WPos = mul( MPos, World );
OUT.Light0 = Point0Pos - WPos;
OUT.Light1 = Point1Pos - WPos;
OUT.Eye = ViewInverse[3].xyz - WPos.xyz;
// Screen Space
OUT.HPos = mul( MPos, WorldViewProject );
return OUT;
float4 BorderVS( appdata IN ) : POSITION
// Do Border in World so units remain sensible.
float3 WPos = mul( float4( IN.Position.xyz, 1 ), World ).xyz;
float3 Norm = mul( IN.Normal.xyz, WorldInverseTranspose ).xyz;
WPos += Norm * BorderThickness;
float4 HPos = mul( float4( WPos, 1), ViewProject );
return HPos;
float4 DebugVS( appdata IN ) : POSITION
return mul( float4( IN.Position.xyz, 1), WorldViewProject );
// PIXEL UTILITY
float3 NormalFromTex2D( sampler2D normalSampler, float2 uv )
return ( tex2D( normalSampler, uv ) * 2 - 1 );
struct FragData
float3 Normal;
float3 Eye;
FragData Frag( float3 Normal, float3 Eye )
FragData OUT;
OUT.Normal = Normal;
OUT.Eye = normalize( Eye );
return OUT;
struct Light
float3 Position;
float3 Direction;
float3 Color;
float Attenuation;
Light PointLight( float3 pos, float3 vec, float3 col, float constFall, bool linFall, float quadFall )
Light OUT;
OUT.Position = pos;
OUT.Direction = normalize( vec );
OUT.Color = col;
float mag = length( vec );
float atten = constFall + linFall * mag + quadFall * mag * mag;
OUT.Attenuation = saturate( 1 / atten );
return OUT;
float Accumulate( FragData frag, Light light, inout float3 diffuse, inout float3 specular )
// Lambertian Diffuse
float LdotN = dot( light.Direction, frag.Normal );
// Phong Specular
float3 R = normalize( 2.0f * frag.Normal * LdotN - light.Direction );
float RdotV = dot( R, frag.Eye);
float phong = pow( saturate( RdotV ), SpecularPower );
// Toon Modification
float toonDiff = smoothstep( DiffuseToonMin, DiffuseToonMax, LdotN ) ;
float toonSpec = smoothstep( SpecularToonMin, SpecularToonMax, phong ) ;
// Apply Light Factors
toonDiff *= light.Attenuation;
toonSpec *= light.Attenuation;
diffuse += toonDiff * light.Color; // Lambert
specular += toonSpec * light.Color; // Blinn
// Return the lighting amount. Useful for masking.
return toonDiff;
// PIXEL
float4 SemiToonPS(vertexOutput IN) : COLOR
float3x3 TBN = float3x3( IN.Tangent, IN.Binormal, IN.Normal );
float3 Normal = NormalFromTex2D( NormalMapSampler, IN.UV );
FragData frag = Frag( mul( Normal, TBN ), IN.Eye );
float3 diffTerm = 0;
float3 specTerm = 0;
float lit = 0;
if( UsePoint0 )
Light light0 = PointLight( Point0Pos, IN.Light0, Point0Col, Point0Constant, Point0Linear, Point0Quadratic );
lit += Accumulate( frag, light0, diffTerm, specTerm );
if( UsePoint1 )
Light light1 = PointLight( Point1Pos, IN.Light1, Point1Col, Point1Constant, Point1Linear, Point1Quadratic );
lit += Accumulate( frag, light1, diffTerm, specTerm );
// Clamp lighting Values.
diffTerm = saturate( diffTerm );
specTerm = saturate( specTerm * SpecularIntensity );
lit = saturate( lit );
diffTerm += ( 1 - lit ) * AmbientLight;
float4 diffTex = tex2D( DiffuseMapSampler, IN.UV );
float4 specTex = tex2D( SpecularMapSampler, IN.UV );
diffTerm *= DiffuseColor * diffTex.rgb;
specTerm *= SpecularColor * specTex.rgb;
return float4( diffTerm + specTerm, diffTex.a);
float4 BorderPS ( float4 Position : POSITION ) : Color
return float4( BorderColor );
float4 DebugPS ( float4 Position : POSITION ) : Color
return float4( 1, 0, 0, 1);
// Technique
technique transparent
pass depth
{ // Depth pre-pass so there isn't overlap in the transparency
VertexShader = compile vs_2_a DebugVS();
PixelShader = compile ps_2_a DebugPS();
ColorWriteEnable = false;
ZEnable = true;
ZWriteEnable = true;
CullMode= cw;
pass body
{ // Draw the Toon Shaded Body
VertexShader = compile vs_2_a SemiToonVS();
PixelShader = compile ps_2_a SemiToonPS();
ColorWriteEnable = Red | Green | Blue | Alpha;
// Create a Mask for where the shape was
StencilEnable = true;
StencilRef = 1;
StencilFunc = ALWAYS;
StencilPass = REPLACE;
AlphaBlendEnable = true;
SrcBlend = SRCALPHA;
DestBlend = INVSRCALPHA;
ZEnable = true;
ZFunc = EQUAL;
ZWriteEnable = false;
CullMode= cw;
pass outline
{ // Draw The border
VertexShader = compile vs_2_a BorderVS();
PixelShader = compile ps_2_a BorderPS();
// Draw only where the mask is not.
StencilRef = 1;
StencilFunc = NOTEQUAL;
ZEnable = true;
ZFunc = LESSEQUAL;
CullMode= cw;
pass cleanup
{ // Erase the stencil. Write Expanded shape to ZBuffer
// Reset Mask
StencilPass = ZERO;
ZEnable = true;
CullMode= cw;
technique opaque
pass body
StencilRef = 1;
ZEnable = true;
CullMode= cw;
pass outline
StencilRef = 1;
ZEnable = true;
ZFunc = LESSEQUAL;
CullMode= cw;
pass cleanup
// Reset Mask
StencilPass = ZERO;
ZEnable = true;
ZFunc = EQUAL;
CullMode= cw;
technique simple
pass p0
ZEnable = true;
CullMode= cw;
