really simple question
pm.select (‘obj.vtx[4]’) select vertex but not select object
What’s the question? Are you saying you want it to also select the object?
node = pm.PyNode('obj')
pm.select(node)
pm.select(node.vtx[4], add=True)
# Change the selection mode to component if needed
pm.selectMode(component=True)
thank you very much. ) yes it is exactly what I’m looking for. PyMel documentation says selectMode is not editable so I even don’t try it
