Red9 StudioPack v1.29 Released
Just a quick note to say I’ve finally released Red9 StudioPack v1.29 with some major updates and a lot of small fixes.
The main changes are already discussed below in a previous thread:
http://red9-consultancy.blogspot.co…9-released.html
http://red9-consultancy.blogspot.co…oming-soon.html
http://red9-consultancy.blogspot.co…cker-vimeo.html
A few major ones:
[ul]
[li]CameraTracker - new feature for tracking animated objects in the current view - see Vimeo demo
[/li][li]PoseSaver updates - now supports SubFolders both in local and project - the sync allows poses to be synced and folder sub-structures generated if they’re not found
[/li][li]Most of the UI’s now have a ‘VimeoHelp’ menu that takes you straight to the video demo. I’m trying to do one of these per tool so you have full interactive help on everything.
[/li][li]MetaData now has a new MetaHUD class that I’m working on which gives you really easy access and management to the HUD (this is work in progress at the moment)
[/li][li]
[/li][/ul]
I’ve also started a changeLog and am going to be moving the code to a public repository at some point soon so all you coders out there will be able to see commits and code changes.
Once again thanks for all the support
Mark
