Welcome to my ongoing thread dedicated to RealTimeVFX in Unreal Engine 5 Niagara!
I am Ashif Ali, a Real-Time VFX artist creating breakdowns and tutorials over at CGHOW. I created this master thread to share all my latest Niagara workflows, shader tricks, and technical particle setups in one central spot for technical artists, game developers, and VFX creators.
What I will be posting here:
Niagara System Architecture: Custom modules, scratch pads, particle logic, and emitter setups.
Iโll be updating this thread regularly as new tutorials drop. Feedback, questions on logic nodes, or suggestions for new breakdown topics are always welcome!
Unreal Engine 5 Niagara User Parameters Tutorial | Blueprint Control
In this tutorial, we dive deep into the power of User Parameters in Unreal Engine 5 Niagara and how to control them using Blueprints. Iโll show you why a VFX is only truly โfinishedโ when a game programmer can easily modify it for gameplay. What you will learn: Niagara Timeline Basics: How to use the timeline to play, reverse, and add offsets to multiple emitters (like red and green particle systems). Creating User Parameters: How to expose variables like Color, Life, and Size so they can be tweaked directly in the viewport without duplicating assets. Blueprint Integration: Step-by-step guide on creating an Actor Blueprint, adding a Niagara component, and using the Set Niagara Variable (Float) node to create randomized effects. Practical Application: See how to make every spawned effect unique by using random ranges for parameters like โLife.โ
Fix Ribbon Texture Tiling & Stretching in UE5 | Mini Tutorial #4
Stop letting your particle ribbon textures stretch and distort! In this quick Unreal Engine 5 mini-tutorial, learn two ways to properly tile textures along ribbons in Niagara.
We cover:
Setting up a Dynamic Parameter in your material graph to control UV tiling directly.
Fixing movement-based stretching by switching the Ribbon Renderer UV mode to Tiled (By Segment Length) for consistent, distortion-free repetition no matter how long the trail gets!
Stay tuned for daily 30-to-60-second tips breaking down single tools, nodes, and VFX tricks across Unreal Engine 5, Niagara, Materials, and Blender!
Radial to Shockwave in UE5 Niagara! | Mini Tutorial #3
Learn how to turn a basic procedural radial gradient into a dynamic shockwave in Unreal Engine 5! In this quick mini-tutorial, see how to modify the material graph using RadialGradientExponential, invert the mask, and drive the expansion using Scale Sprite Size and Scale Color (Alpha curve) inside Niagara.
This technique eliminates the need for imported ring textures, giving you infinite-resolution, fully adjustable shockwaves and impact rings for explosions, ground slams, and energy bursts with zero texture memory overhead!
