Does anyone know the skinCluster flag to turn off multiple bind poses. They did have ignoreBindPose, which is now redundant
Hey,
I looked into you question and, assuming that you are creating your skin clusters yourself, you have a few options.
Firstly, you can use the skinCluster command and manage the bindMethod by giving it an int value of: “0 - Closest distance between a joint and a point of the geometry. 1 - Closest distance between a joint, considering the skeleton hierarchy, and a point of the geometry. 2 - Surface heat map diffusion. 3 - Geodesic voxel binding” (Maya Documentation).
For example:
cmds.skinCluster(bindMethod=1, toSelectedBones=True)
But if you want to manage existing bind poses, you can make a simple script that removes them.
joints = cmds.ls(sl = True)
for i in joints:
cmds.select(i, r = True)
bind_pose = cmds.dagPose( q=True, bindPose=True )
if bind_pose:
cmds.delete(bind_pose)
You can of course make it more specific and target only specific bind poses or only the children of certain nodes.
Hi EmilVoychev,
I do create my skin cluster. My code was loading saved weights back on the rig with new skin cluster. Regarding bind poses, I did the same approach you suggested and deleted the bind pose and created a new one. That solved my problem.
Thanks for your update.
