how to perform ‘as’ convert operation in pymxs ?
In maxscript, for example:
– make a quat
q = quat 0 0 0 1
– convert to matrix
m = q as matrix3
and now, how can i do that in pymxs ?
from pymxs import runtime as rt
q = rt.quat(0,0,0,1) # make a quat
m = ?? # how to conver it to matrix
you need to make a globally accessible maxscript function and then you can call it from python:
MyUtils.ms:
// Wrap in a struct to provide a namespace:
struct MyUtils(
fn ConvertMxsType value type =(
value as type
// Create a global instance:
MyUtilsInstance = MyUtils()
from python:
from pymxs import runtime as mxRt
# Make sure your MyUtils.ms file has been evaluated so the struct is available in pymxs.runtime:
mxRt.FileIn("MyUtils.ms")
# Convert using the function:
m = mxRt.MyUtilsInstance.ConvertMxsType(q, mxRt.Matrix3)
print(m)
its a way to do it, but a little bit complicated…
Welcome to 3DsMax!
The issue is that the pymxs is just an automatic wrapper - there are little to no convenience functions added so you have to do those yourself.
