I hope this post helps someone out. And or if someone knows better to help me out
Setting up MayaCharm connection to Maya running on a MacOS
(I’m on 2023 sp3, and Sonoma OS)
Follow instructions for MayaCharm.
- Maya: add your command port command to you’re favorite and most secure way of executing it
- PyCharm: MayaCharm Plugin, Ensure MayaCharm’s command port are the same
- Fix for MacOS privacy and security settings below.
DISCLAIMER THIS IS A SECURITY RISK
–check with IT for command port exposure, or security changes to your hardware–
–especially if you work from home, open files from external vendors, work with others working from home–
Under Privacy and Setting | App Management | Add Application (+)
And add you’re Maya App from the application folder.
–There is a popup the first time this occurs that you may catch, with the ability to click allow, again think about security folks–
