I’m doing a production tool which copy files between folders in our pipeline, on Windows 10. My problem is that some files have been renamed with copy/paste by some people, and it seems to add illegal characters in the file names. Those characters are invisible in explorer.exe:
The illegals characters are between ‘0’ and ‘3’ (you should be able to cc them): pixPath = u"E:/col_udim_test.1003.jpg"
os.rename and shutil.copy give errors when trying to handle the files:
os.rename(path + f, path + unicode(f))
WindowsError: [Error 123] La syntaxe du nom de fichier, de repertoire ou de volume est incorrecte
shutil.copy(path + f, path + 'test/' + unicode(f).replace('?', ''))
with open(src, 'rb') as fsrc:
IOError: [Errno 22] invalid mode ('rb') or filename: 'E:/col_udim_test.100?????3.jpg'
Trying to get hexa of illegal character n: hex(ord(n)) gives me0x200b`
Anyone have an idea how to clean those file names? I was thinking about converting the unicode to hexa, remove unwanted hex and convert back to unicode,
Thanks for your quick answer Chalk.
That will allow me to clean the strings inside python, but I still can’t handle the files with os or shutil. It seems they can’t work with blated filenames.
Do you know of an obscure python module which would do the trick ?
Might have to brute force this one - I’m more of a bat file man myself, but PowerShell is all the rage these days - this may get you through. Please test with example data first - PowerShell path to your folder location, then:
