Problem with Pywin32 on Windows 7, Python 3.1.1
Hello, I was just looking for someone who could help me out: I’ve installed Pywin32 batch 214 for Python 3.1, I give it the simple command of
>>> import win32com.client
>>> win32com.client.Dispatch(dispatch=“Word.Application”)
and I get a long error message:
File “<interactive input>”, line 1, in <module>
File “C:\Python31\lib\site-packages\win32com\client_init_.py”, line 95, in Dispatch
dispatch, userName = dynamic._GetGoodDispatchAndUserName(dispatch,userName,clsctx)
File “C:\Python31\lib\site-packages\win32com\client\dynamic.py”, line 104, in _GetGoodDispatchAndUserName
return (_GetGoodDispatch(IDispatch, clsctx), userName)
File “C:\Python31\lib\site-packages\win32com\client\dynamic.py”, line 84, in _GetGoodDispatch
IDispatch = pythoncom.CoCreateInstance(IDispatch, None, clsctx, pythoncom.IID_IDispatch)
pywintypes.com_error: (-2147221005, ‘Invalid class string’, None, None)
I’m not sure if this is relevant, but I only have Openoffice installed, not any Windows Office, does it even matter?
Thanks for the help!
Hello All,
I have used Adam’s code to try my hands on in using python in case of PSD
I need a tool to compare two psd files and give difference of both (layer width/height mismatch etc)
To start with ,I am using below piece of code to read through a psd file.A partial code chunk is printed below:
if (name == ‘main’):
# COM dispatch for Photoshop
psApp = win32com.client.Dispatch(‘Photoshop.Application’)
options = win32com.client.Dispatch(‘Photoshop.ExportOptionsSaveForWeb’)
Error:
Any suggestions?
You can try use the code described here to get more info on the error:
