Has anyone made a mirrored control setup in Motionbuilder before so that translating two controls in the X axis at the same time will move the controls in opposing directions? In Maya, you can set the scale to -1 in the axis you want to mirror to achieve this, but Motionbuilder seems to behave differently when moving multiple objects at the same time. It’s almost as if it only cares about the orientation of the last selected object.
Okay, thanks for confirming. I’m going to pose one side and have a tool to mirror selected controls for now. Maybe in the future something can be done with relation constraints.
Thanks for the suggestions. I didn’t have luck using pose mirror on two opposing effectors in a single extension. I saw results when I pasted in full body mode, but nothing happened in selection mode. Maybe I need to make sure the extension is setup properly. I did have success copying and pasting the local trs values and flipping the proper axis like you mentioned though. I still need to test moving the effectors in the properties tab with - scale.
