a simple newb question…how do I use findRelatedSkinCluster in python?
#want name of skin cluster on selection
import maya as cmds
selection = cmds.ls(sl=True)
item= selection[0]
print cmds.eval('findRelatedSkinCluster'+item)
esult:
import maya as cmds
item= selection[0]
esult:
i think your after maya.mel.eval rather than maya.cmds.eval.
(and add a space between the command string and the object)
what Lee said or if you want to traverse to find it you could pymel and make it easy
import pymel.all as pm
jnt = pm.ls(sl=True)[0]
skinCluster = None
for node in jnt.connections():
if node.nodeType() == 'skinCluster':
skinCluster = node
break
thanks! this is what worked:
import maya as cmds
item= selection[0]
print cmds.mel.eval('findRelatedSkinCluster '+item)
I usually import cmds and mel separately. Here’s the way I would have done it (though I don’t know what the “preferred” way is.)
import maya.mel as mel
item= selection[0]
print mel.eval('findRelatedSkinCluster '+item)
On another note, I’m surprised your code isn’t giving an error on the second line. Wouldn’t it have to be the following to work?
selection = cmds.cmds.ls(sl=True)
you’re right. my typo bad.
