Maya, PySide2 and relative paths
I’m having some problems with relative paths in Maya and PySide2.
I understand all Maya’s buttons are bundled in a file,
but since I don’t understand exactly how it works
why doesn’t using relative paths work for my own custom icons?
My custom icons that are inside custom defined icon paths works with maya.cmds
window = cmds.window()
cmds.rowColumnLayout( adjustableColumn=True )
cmds.iconTextButton( style='iconAndTextVertical', image1='orient_top.png', label='top' )
cmds.iconTextButton( style='iconAndTextVertical', image1='orient_front.png', label='front' )
cmds.iconTextButton( style='iconAndTextVertical', image1='orient_side.png', label='side' )
cmds.showWindow( window )
PySide2 example
does not work with my custom icon
btn1 = MyPushButton("my_icon.png")
or
btn1 = MyPushButton(":/my_icon.png")
works with Maya native icons
btn1 = MyPushButton(":/cube.png")
my solution in PySide2
get the path to the file itself
path = os.path.dirname(os.path.abspath(__file__))
# because I’m using modules I have an icon folder in every collection
btn1 = MyPushButton(path+"/icons/my_icon.png")
and while I am on the topic. Why is it that when I create a new shelf button, navigate to my button that is in an icon folder that I’ve added to Maya, it still shows the full absolute path so I manually have to go in and remove the whole folder path to just have the icon name left. I do this with a script, but anyway. Is there any other workaround for this?
As far as I know to be able to use relative paths for images with PySide you’d need to either build the path relative to __file__ as you show, or compile a qrc (xml file listing relative paths etc) to a python module using the pyside2-rcc executable that comes with PySide.
On Windows this would be something like:
>>> pyside2-rcc.exe .\my_resources.qrc -o my_resources.py
With this you can then import my_resources and reference whatever you’ve compiled to it using that format available with the builtin icons, eg
":/my_icon.png"
Ah thank you. Interesting. Very cool. And welcome! =)
