Hey there, I want to bake adjustments to a file node in Maya. Is there an easy way to bake it out without applying it to an object and using convert to texture.
Before I code it - just want to make sure there is no built in command to spit out the simple adjustments like exposure to a new file ?
is ‘convertSolidTx’ the only way forward ?
Thanks.
A
you mean you want to use the file attributes to adjust the image and then spit out the adjusted version to another image?
Yes exactly!
I think that command is as simple as it gets tbh.
I want to make a button to overwrite adjustments to the original file. Eg tiny exposure adjustment…
This is to work with Stingray shaders without popping into Photoshop.
Mambo4
July 21, 2023, 1:23pm
5
I recall doing something similar in 3DS Max - capture a manipulated texture image. It involved using the renderer to generate the updated image.
Arnold has a Render to Texture feature
convertSolidTx
Command is great… There is a -sampleplane command so you can export any render node… So all very simple…
Yes. Or use MEL or Python command arnoldRenderToTexture
cmds.arnoldRenderToTexture([shape], # or selected shape
folder = outFolder,
shader = shader,
resolution = resolution,
aa_samples = aa_sampling,
filter = filter_type,
filter_width = filter_width,
all_udims = all_udims,
udims = udims,
uv_set = uv_set,
normal_offset = normalOffset,
enable_aovs = enableAovs,
extend_edges = extendEdges,
u_start = uStart,
u_scale = uScale,
v_start = vStart,
v_scale = vScale,
sequence = useSequence,
frame_start = frameStart,
frame_end = frameEnd,
frame_step = frameStep,
frame_padding = framePadding)
For example:
cmds.arnoldRenderToTexture('pCubeShape1', folder = r'C:\temp', all_udims = True, resolution = 4096)
