Hi all, is it possible to generate a guid through maxscript?
Not that I am aware of. You can use the .NET System.Guid.NewGuid() method.
thanks I ended up using MaxPlus and uuid lib,
but thanks anyway
You can generate a new class ID:
https://help.autodesk.com/view/3DSMAX/2017/ENU/?guid=__files_GUID_E59FCB9A_04C0_4228_9779_4FD74F2D35AD_htm
Hey elpie89,
This is something I did a while ago that might help. I’m assuming your goal is to make types hashable for testing membership in a list/set.
def __INode_eq__(self, other):
try:
if self.__hash__() == other.__hash__():
return True
return False
except:
return False
MaxPlus.INode.__eq__ = __INode_eq__
def __INode_hash__(self):
return hash(self.GetHandle())
MaxPlus.INode.__hash__ = __INode_hash__
I’d probably change this to:
try:
return isinstnace(other, MaxPlus.INode) and hash(self) == hash(other)
except TypeError:
return False
Mostly because it avoids the bare except and I like to double check that the instances at least share some parent type.
Also, its good practice to use the protocol’s function instead of calling the dunder method directly.
i find this : genguid()
