I have got a problem with node’s array output. I use MArrayDataHandle and MArrayDataBuilder to create data output. It seems like all works except data with index [0], other data is correct.
I do it with this piece of code:
arrayDataHandle = om.MArrayDataHandle( data.outputArrayValue( vfk_node.oRotate ) )
outputArrayBuilder = om.MArrayDataBuilder( data, vfk_node.oRotate, 0 )
elementHandle = om.MDataHandle( outputArrayBuilder.addLast() )
elementHandle.set3Float( 1.0, 2.0, 3.0 )
elementHandle.set3Float( 4.0, 5.0, 6.0 )
elementHandle.set3Float( 7.0, 8.0, 9.0 )
arrayDataHandle.set( outputArrayBuilder )
The outputs of oRotate are:
[0] 0, 0, 0
[1] 229.183, 286.479, 343.775
[2] 401.07, 458.366, 515.662
Looks like outputs are multiplied by degrees/radians conversion ratio, I can deal with that later, but output [0] is not set at all.
Am I missing something?
