Hey guys,
My problem is not seem to be very hard but I cannot solve it.
I am trying to script with Python Fbx SDK to scale models. And I am using LclScaling.Set() to set scale value. But I found if this model has keyframes, then the scaling is not applied.
So my question is how to properly scale models that have keyframes. Here is my code:
scale = node.LclScaling.Get()
value = self.scale_factor
node.LclScaling.Set(fbx.FbxDouble3(scale[0] * value, scale[1] * value, scale[2] * value))
I figured it out. In Maya, if I set translate or rotate keyframes, the scale property would also has Animation Node in FBX SDK. So, if I want to modify scale property, I should use SetChannelValue or FbxAnimCurveFilterScale instead of LclScaling.Set().
Hi.
Man in this moment I’m making the same in python but doesn’t work please help me to solved this I need to scale a node, from python but doesn’t work here my code in auto desk forum. FOr now I can get the meshes points and vertices and draw in my engine game but I can’t scaling using LclScaling.Set(). please help, My email is andrestronic12@gmail.com write me I can pay for that.
How to Scale A node Using FBX SDK python or C+ - Autodesk Community - FBX
