this question is like the most important thing that i want to know, I dont know why its not discussed anywhere, but I am sure their is a way, using python,
can anyone please tell me how can i open the maya scene file<not in maya> with python script get the list of camera or render globals setting make changes to the setting and save back…
because sometimes all it is required to change camera to be rendered or some setting for that opening a heavy scene could be a waste of time…
If it’s a mayaAscii file, you can parse it as a text file and find or add/remove the creation and attribute setting of cameras and renderGlobals.
If it’s a mayaBinary file (or you don’t want to parse a text file), you can use the mayapy.exe python interpreter in maya/bin. It’s a python interpreter with the necessary environment variables set so you can open maya scenes and run python scripts on the open scene.
import maya.standalone
def standalone_template(file_to_open):
# Start in batch mode
maya.standalone.initialize(name='python')
cmds.file(file_to_open, f=True, o=True)
# Do your magic here
# Save it
cmds.file(s=True, f=True)
You would then launch that script with the mayapy interpreter
So I am trying to run the method below from python script [RenderUI.py] and read data returned by it using mayapy but don’t know why i am not getting the correct result even if the logic seems to be right…
def readFile(self):
## call to readMayaFile.py using mayapy.exe interpreter
fileToOpen="I:/scenes/san_telus_pan_v009.ma"
code_str = \
import readMayaFile
readMayaFile.getCams("""+fileToOpen+""")
# save the code
phile=os.path.join(os.path.split(__file__)[0],"test.py")
filename=phile
fout = open(filename, "w")
fout.write(code_str)
fout.close()
# execute the code with mayapy and pipe the result to a string
mayapy="D:/Program Files/Autodesk/Maya2013/bin/mayapy.exe"
test = mayapy+" " + filename
process = subprocess.Popen(test, shell=True, stdout=subprocess.PIPE)
process.wait()
print process.returncode,"<" # 0 = success, optional check
# read the result to a string
strRead = process.stdout.read()
print strRead
the readMayaFile.py contains :
#mapay interprer file
import os
def getCams(phileToOpen):
cmds.file(phileToOpen, force=True,open=True)
cams=cmds.ls(type="camera")
return cams
Can anyone please help me figure out what am I doing wrong in the implementing the logic in readFile() method ?
First off, you might want to just setup a single script rather than writing out to a second file. You can pass arguments in to python and get them back with sys.argv:
if __name__ == "__main__":
import sys, os
args = sys.argv
this_script = args[0] #this will be the name of this file
target_file = args[1] #this would be the first argument you passed in
maya.standalone.initialize()
try:
cmds.file(target_file, open = True, force = True)
sys.stdout.write(",".join(cmds.ls(type='camera')))
quit()
except RuntimeError:
sys.stderr.write('could not find %s
' % target_file)
raise
The call pass in filename of the script above and the filename of the file you want to check to your subprocess as arguments
I decided instead of just returning the cams so i modiefied the code above and retured dictionary in the form of string coz returning dectionary was giving me error
[QUOTE=Theodox;19327]If you really want to send complex data between processes, try something like pickle or json[/QUOTE] that would mean write to disk operation?
Not necessarily. Pickle converts objects into a format that can be stored/transmitted. You can still pass pickled (or json) data between processes like you were doing with the stringified dictionary.
well, i tried the same with nuke as well got success reading file from nuke but
when i return to stdout.read() i am getting index out of range error
Success Reading : 09_color_correct_track_end.nk
File “\RenderUI.py”, line 384, in execApp print pickle.loads(process.stdout.read())
File “D:\Python26\lib\pickle.py”, line 1374, in loads
return Unpickler(file).load()
File “D:\Python26\lib\pickle.py”, line 858, in load
dispatchkey
File “D:\Python26\lib\pickle.py”, line 1203, in load_setitems
mark = self.marker()
File “D:\Python26\lib\pickle.py”, line 874, in marker
while stack[k] is not mark: k = k-1
IndexError: list index out of range
just trying to print before i use the data, what else is returned then
this is how I dump with pickle
try:
import nuke
# Open nuke script
nuke.scriptOpen(target_file)
wrtNodelst=[]
allWriteNodes=nuke.allNodes("Write")
for index,each in enumerate(allWriteNodes):
wrtNodelst.insert(index, each.name())
sys.stdout.write(pickle.dumps(wrtNodelst))
quit()
' % target_file)
raise
is it because i am reading data object that didnt wrote the pickle object ?
