Hi all,
I’m looking to run a playblast on a machine without graphics card or monitor, mainly involving Maya, but applies to any DCC with a GPU requirement.
The requirements are simple; produce the exact same result as cmds.playblast() but via the command-line, on a blind machine.
$ mayapy -c "from maya import standalone, cmds; \
standalone.initialize(); \
cmds.playblast(filename='/root/workspace/my_playblast')"
Worth noting, the above works well on a machine with graphics card and monitor. So all I need is some way of emulating the windowing system and GPU.
For usecase, think of dispatching playblasts of computationally heavy animations (300 frames, <30 seconds each) to a farm so as to save some of that local RAM and keep working.
I know this has been attempted and failed before, by greater developers than I, and I can see why. Playblasts are screengrabs of an OpenGL viewport and OpenGL runs on the GPU. No GPU == No viewport.
Mesa can solve that.
The next why is that playblasts are dependent on a window. Something to screengrab from. Even with offScreen=True(?)
Xvfb can solve that.
At this point I’m at a loss. The command successfully finishes, throws a few warnings, and produces a quicktime file with no content.
Full reproducible
Either install Maya and the list of dependencies from above or use the pre-built Docker image like.
$ docker run -ti --rm -v $(pwd):/root/workspace mottosso/maya
[root@343 ~]# mayapy -c "from maya import standalone, cmds; \
cmds.playblast(filename='/root/workspace/myplayblast')"
[root@343 ~]# exit
$ hexdump -C my_playblast.mov
00000000 00 00 00 20 66 74 79 70 71 74 20 20 20 05 03 00 |... ftypqt ...|
00000010 71 74 20 20 00 00 00 00 00 00 00 00 00 00 00 00 |qt ............|
00000020
