Hey there I have a rename script with a custom UI. The textField is populated with the current selection. It would be handy to have this text selected on generation of the UI as usually I would overwrite the name.
I don’t see a command to select contents in ‘textField’. ‘setFocus’ doesn’t throw up anything either.
Basically, my script pops up and I want something to trigger ‘ctrl+a’ to select the contents. Am I overlooking something simple ?
Thanks Alan.
Hello,
I am not sure this is possible with Maya cmds API. But it is definitely possible with Qt, here is an example:
from PySide2 import QtWidgets
import maya.OpenMayaUI as mui
import shiboken2
class TestWindow(QtWidgets.QDialog):
super(TestWindow, self).__init__(parent)
main_layout = QtWidgets.QVBoxLayout()
textfield = QtWidgets.QLineEdit()
textfield.setText("bonjour")
textfield.selectAll()
main_layout.addWidget(textfield)
self.setLayout(main_layout)
def getMayaWindow():
ptr = mui.MQtUtil.mainWindow()
return shiboken2.wrapInstance(int(ptr), QtWidgets.QWidget)
def main():
global ui
ui = TestWindow(getMayaWindow())
ui.show()
if __name__ == "__main__":
main()
Hope you find this useful
Cheers !
Thank you for taking the time to respond, that is amazing. Really appreciate that. I was going to trigger at command line utility to do a keystroke! (ctrl+a).
Very hacky but who cares for personal workflow!
Using a utility that can trigger key press… so this runs just after UI is shown in MEL.
//trigger c+a using hotkey p to select all text as no other way to do it.
system("call \"%USERPROFILE%/Programs/HotkeyP/HotkeyP.exe\" -macro \\ctrldown\\A\\ctrlup");
