Channel Box Adventures Part 1
So after asking about the channel box a number of times, on many forums, then concluding its poorly left behind by its equivalents in other DCCs, I decided I needed some custom guardrails, or I will be going crazy, am not jesting.
With the very short time I had (as always) and keeping my limited knowledge of programming in Maya, in mind, I endeavoured to solve two issues:
  • A quick and natural way to navigate or select the attributes I use 99% of the time, especially at node creation (new bevel, merge, et all)
  • A consistent, natural means of finetuning or hyper-tuning attribute(s)
The above issues been a never ending affair, I asked about it as far back as a few days ago, with the channel editor, is it not possible to increment by 0.01?
After using these features for a day, I am very happy with them, and I thought I would share what I came up with.
I would like to continue with “beta” testing and incrementally improve things as needed, then eventually share the project as an open source release, if you are interested, feel free to let me know.
Finally, I would like to thank the fellows on tech-art and elsewhere, who were kind and especially patient with me over the months with my basic questions.
Integrating the channel box into my new “system”
The first order of business, I wanted the channel box to work with me and not against me. At least, in the part that it excels at, which is selecting attributes (it sucks at adjusting attributes)
A means of quickly cycling through “common attributes”
This one in particular is one that was driving me crazy. How often I have wanted, after I applying a bevel or a vertex merge, to just cycle through the 2 or 3 attributes that I care to change 99% of the time, for quick interactive adjustment.
So I took each node type, and designated a few of its attributes as “most common”.
Automatically expand any new node in the “INPUT” section, and select the “most common” attribute
The channel box in its goal hinder some more, shows new nodes in a collapsed state, under the “INPUTS” section. This feature will automatically expand any new nodes in the “INPUT” section, and select that nodes “most common” attribute.
300
Quickly cycle through “common attributes”
Furthermore, its possible via a dedicated hotkey to cycle between attributes designated as “most common” for that same node
In this case, its set to cycle between, Fraction, Segments and Chamfer, which are the attributes I uses 99% of the time.
300
Quickly mass select arbitrary attributes
Of course, I cant designate every attribute as “most common” attribute, so I needed a additional method to quickly, mass select or deselect various attributes, without having to go to my second, third monitor, drag the channel editor, et all.
Instead, this method on key down, temporarily moves the channel box to under my mouse, allowing me to select attributes, then key up restores its position.
300
Well that is it for the channel box and for cycling through attributes. Lets see how to adjust attributes themselves.
Attributes adjusting method 1: scrollwheel
quickly increment/decrement most common attributes for a node, right after creating it
This brings brings to a issue I often found myself lacking for, after applying a Bevel or a Merge, to just quickly and interactively adjust the most common attributes, in this case segments or distant threshold, respectively.
Since, the “most common” attribute of new nodes are automatically selected, I can simply adjust the value via scroll wheels, jog wheels, keyboard keys, etc:
box.chan_shift(delta_int=-1, delta_float=-0.01)    #this is for incrementing
box.chan_shift(delta_int=-1, delta_float=-0.01)    #this is for decrementing
box.chan_shift(delta_int=10, delta_float=0.5)      #increment in large jumps
Unlike, the other methods I built, this method does not use mouse dragging, but repeated calls via a hotkey. I wanted a way to increment (or decrement) values
You can see the adjusting in action here, the function will adjust any attribute, be it a bool, int, floats, even enums.
I have several wheels that can “hyperscroll”, so I was concerned if Maya can keep up, but surprisingly I have not had any issues.
300
attributes adjusting method 2 : MMB dragging
And of course the MMB drag is available too, right after applying a node (I think that is what its called, still new Maya…), its possible to adjust the common attribute by holding down MMB.
In this case, the primary “common attribute” is divisions
300
attributes adjusting method 3 : interactive viewport adjustments
This class was the main focus of what I wanted to build, a way to jump between nodes or attributes and to seamlessly adjust them, with fine gradual precision.
Its possible to bind to a key, wtih the following:
drag = chan_drag()
drag.activate(noMod=0.1, ctrl=0.01, shift=1.0)  #with another key(s) dedicated to moving to next/prev nodes
Its also possible to directly dedicate a key to a single node type or attribute, which is very useful when animating:
#can also "hard code" to a specific node type and its attribute
drag.activate(address="polyBevel3.f", noMod=0.1, ctrl=0.01, shift=1.0)
And a small part of the class in action, once again, Maya kept up with the performance
300
