Accessing Render Classes
I am trying to write a script that will auto setup Mental Ray or the Scan Line renderer with the best setting for an AO map. I have found a script that gives me a good jumping off point but I have hit a stumbling block that I am not sure how to get around. I think my problem is that when trying to set values in the Mental Ray engine via script, my script values look like they are not being passed. Here is the code that I am working with.
-- script for quickly change render settings
test = mental_ray_renderer()
if (( mainRoll != undefined) and ( mainRoll.isdisplayed)) do
(destroyDialog mainRoll ) -- test if dialog exist
fn checkRender nSearch =  -- function check if render installed
	theRenderer = for obj in RendererClass.classes where
	  (matchPattern (obj as string) pattern:nSearch) -- check if the name in nSearch variable exist
		collect  obj
		if theRenderer.count ==1
		   then  renderers.current = theRenderer[1]()
 else
		 (messageBox "render not  installed")
rollout mainRoll  "ChangeSetting"
	group "Change Render" -- define change render buttons
	  button butScanline "Scanline" align:#left across:2 width:70 height:20
	  button butMR "Mental Ray" align:#left width:70 height:20
	  button butVray "Vray" align:#left  across:2 width:70 height:20
	  button butKrakatoa "Krakatoa"  align:#right  width:70 height:20
	on butScanline pressed do
	varScan = "*Scanline*"
	checkRender varScan
	on butMR pressed do
	print(test)
	varMR = "*mental_ray*"
	checkRender varMR
	test.glossyreflectionsprecision = .95
	print(test.glossyreflectionsprecision)
	test.BoxFilterWidth  = 8.0
	test.BoxFilterHeight = 8.0
	test.FinalGatherEnable2 = true
	on butVray pressed do
	varVray = "V_Ray_Adv*"
	checkRender varVray
   on butKrakatoa pressed do
	varKrakat = "*Krakatoa*"
	checkRender varKrakat
createDialog  mainRoll  175  450
Right now this code runs but I am pretty sure that it’s not working. The main thing that I do not understand is how to test if using test.“Some Value Here” is working or not because it seams like its not working but its not giving any errors. Any ideas or on what to do or some ideas where to look would be awesome.
You can verify success in many ways.
If you want to disable antialiasing in Scan Line for example, change the renderer to scanline and execute:
crimson = renderers.current
crimson.antiAliasing = false
Notice that antialiasing is now unchecked?
To enable it execute:
crimson.antiAliasing = true
To get all the properties for a given renderer select it in Max and then execute:
show renderers.current
In the listener window you will see something like:
.mapping : boolean
.shadows : boolean
.autoReflect : boolean
.forceWireframe : boolean
.antiAliasing : boolean
.filterMaps : boolean
.objectMotionBlur : boolean
.imageMotionBlur : boolean
.imageBlurEnv : boolean
.imageBlurTrans : boolean
.conserveMemory : boolean
.enablePixelSampler : boolean
.enableSSE : boolean
.wireThickness : float
.objectBlurDuration : float
.imageBlurDuration : float
.antiAliasFilterSize : float
.objectBlurSamples : integer
.objectBlurSubdivisions : integer
.autoReflectLevels : integer
.colorClampType : integer
.antiAliasFilter : maxObject
.globalSamplerEnabled : boolean
.globalSamplerClassByName : TSTR by value
.globalSamplerSampleMaps : boolean
.globalSamplerQuality : float
.globalSamplerAdaptive : boolean
.globalSamplerAdaptiveThresh : float
false
These are all the values that you can change, and what kind of value they are.
Keep in mind, that you may have to close the render setup window and re-open it to see any of these changes.
