Hi, I’m a bit stumped trying to get some world space quaternions with OpenMaya.
I’m getting local space ones with:
(OpenMaya.MFnTransform object).rotation(asQuaternion=True)
I thought It’d be able to get world space ones with:
(OpenMaya.MFnTransform object).rotation(OpenMaya.MSpace.kWorld, asQuaternion=True)
but I get an “(kInvalidParameter): Object is incompatible with this method” error.
Am I doing something wrong? Or if someone has an alternative method I’m happy to hear it
It might be that you are required to initialize the MFnTransform with a MDagPath instead of MObject. Could that be the case?
Just gave this a quick go - that’s indeed the case.
This works
from maya import cmds
# Transform
transform = cmds.createNode("transform")
sel = om.MSelectionList()
sel.add(transform)
# Use MDagPath to make it work
dag = sel.getDagPath(0)
fn = om.MFnTransform(dag)
fn.rotation(om.MSpace.kWorld, asQuaternion=True)
This doesn’t work
obj = sel.getDependNode(0)
fn = om.MFnTransform(obj)
# RuntimeError: (kInvalidParameter): Object is incompatible with this method #
Note the use of an MDagPath does work but an MObject does not.
Ah brilliant, thanks a lot
