I have two shells in a object that are aligned next to one another.
Attempting select all vertices that fall within my marquee rectangle does not work, only a single vertex is ever selected, as shown in the Polygons heads up display.
In this EXAMPLE, on the first marque selection drag, the polygon HUD, says 1 and on the second marquee drag, it says 2.
Is it possible to select all vertices, when they are overlapping? I need to select them so that I can merge both shells into a single shell.
