I’ve always liked tabbed indentation… but apparently I should be using spaces.
Go with what you like, then. There’s pro’s and con’s to both.
I personally see less cons by using spaces, but you may disagree. For example, if you post/see something on the web that’s a python code snippet, it’s going to have spaces. All the python IDE’s or editors I’ve used also allow you to indent with 3-4 spaces and behave as though it’s tabbed-indentation. So hitting tab, or shift+tab, acts as you would expect.
Just as long as you don’t mix spaces/tabs together (man, THAT’S ugly).
