Hi I want to have some things combine in a script but havent found a solution, i use 3dsmax 2019 and sadly chatgpt is really bad at coding for max scripting
can anyone here help me to get exactly this script fixed
if you do what the script does by hand, you will be making this steps
Extract skin data in skin position
snapshot to mesh
copy a new Skin (Skeleton) from the one you want to combine and have the old weights on
Import Skin Data and Match by Name
Done
this way you have a newly mesh with a new skin that have a different skeleton
when you press combine skins in the script it combines the skins
But the script does not combine Perfect the weights
Can you take a look or tell me how can i script the functions i use everyday if you dont want to fix the script?
here is the link for the script
for testing you can simple select one mesh that have same names in bones and see what it does
I Included a Max file so you can test this in Head
for editing the script you can download that in my drive, you install in 3dsmax program files scrip you can read the readme, and the script im testing is the combinedetach skin in resources
if you can help please do, also if you can contact me and want to earn some us while doing i can pay not much but you will not be doing it for free
contact me on my discord
maxthemiracle
Thank you!
Script and test Max
https://drive.google.com/file/d/17fYrho9REe0gUDJsaAvFxuxagyQ26utW/view?usp=sharing
