I’m exploring/debugging someone elses rig.
Is there a way to selective solo a connection?
Currently when a node and run Input and Output Connection, the whole set-up is overwhelming.
I just want to have one node. Click one parameter. And show only the connection of that parameter. And so on and so forth.
Is this possible?
Illustration:
You can limit how deep it shows the connections from the selected node by adjusting the traversal depth.
From maya help :
"Increase/decrease traversal depth
You can customize how far you can see the connections graphed in the Node Editor. By default, depth traversal is unlimited (set to -1).
Use the arrows or enter an integer into the numeric field of the menu bar to change the depth traversal value. Click the Unlimited button or set the number to -1 to remove the depth traversal limit."
https://help.autodesk.com/view/MAYAUL/2024/ENU/?guid=GUID-6AA14E01-4E9D-4DD4-9ECE-49646C9A917C
Thanks! Though not an absolute solution (i.e. I was looking for only a parameter solo selection) but this feature should still get me up and running.
Thanks again! Will close the thread now.
