Scale component of aTransform matrix
I’m diving back in to what Matrix numbers mean. I have read 2 explanations for the scale component of transform matrix. Given the row-major (maya) matrix :
	[ xx xy xz 0 ]
	[ yx yy yz 0 ]
	[ zx zy zz 0 ]
	[ tx ty tz 1 ]
Explanation 1 :
Scale factor is the length of the X Y Z components of the 3x3 rotation sub matrix
	Scale X = length [ xx xy xz ]
	Scale Y = length [ yx yy yz ]
	Scale Z = length [ zx zy zz ]
Explanation 2:
Scale factor is the diagonal elements of the 3x3 rotation sub matrix
	Scale  = [ xx yy zz ]
I suspect Explanation 1 is always correct,
and Explanation2 is only true with no rotation - when it’s a scale matrix only
Is this correct?
You are indeed correct.
In fact, here’s something to play around with to give you a better feel for things. I wrote it for a coworker of mine just last week to explain how matrices work. It’s a rig that directly builds a matrix in Maya. It just plugs the translation values of some objects directly into a fourByFourMatrix node.
You can grab the x, y, and z axes and move them around and see what it does.
Thanks! that will be a fun toy.
Had to update create_shader() to fix the typing to get it running.
from typing import Tuple, List
from maya import cmds
def create_shader(
    rgb: Tuple[float, float, float],
    target: List[str],
    node_type: str = "lambert",
    material: str = cmds.shadingNode(node_type, name=name, asShader=True)
    sg: str = cmds.sets(name=f"{name}SG", empty=True, renderable=True, noSurfaceShader=True)
    cmds.connectAttr(f"{material}.outColor", f"{sg}.surfaceShader")
    cmds.sets(target, edit=True, forceElement=sg)
    cmds.setAttr(f"{material}.color", *rgb, type="double3")
Ah, yeah. My code works in python 3.9 and later. And I’m on Maya 2024 which is python 3.10.
Ugh. And apparently they had a proposal to add those “generic type annotations” to a __future__ import, but they delayed it. And it’s not like maya 2022 is gonna get any python updates :frowning:
It’s probably better to just strip the types for maximum compatibility
good to know that typing stuff got more simple in newer versions
