Do you know if it’s possible to dynamically querry a class name from inside the class definition?
This would be usefull to create snippets in VSCode and avoid forgetting to change the super call.
Something like this:
class Real_class_name(Super_class):
def __init__(self):
getClassName = ???
super(getClassName, self).__init__()
Where ??? would be a function that returns 'Real_class_name'
Because of Maya, I have to work with Python 27, but I’d be interested to know if this exists in either version of Python.
The super call is needed when you need to override a sub class of a base class whose machinery needs to be supported. On the super call you’re not providing a string but the class itself otherwise you’d hit a type error aka:
TypeError: super() argument 1 must be type, not ...
As the bound instance self has a member variable to its class (create via the __new__ magic method) you don’t need to use type inference:
class SubClass(BaseClass):
def __init__(self):
super(self.__class__, self).__init__()
Ah yes! @Theodox - Just tested in repl.it even with derived classes that have it hardcoded the MRO will hit the base class and recursively loop e.g.
class Foo(object):
pass
class Boo(Foo):
def __init__(self):
super(self.__class__, self).__init__() # will work
class Baz(Boo):
def __init__(self):
super(Baz, self).__init__() # Derived class we create recursion error.
I guess it’s safer to keep writing the whole class name then. Really interesting, thanks!
careful: type(self).__name__ seems to returns the name of the actual class called by the instance, even if it is only declared in the super class.
class A(object):
def __init__(self):
self.name = type(self).__name__
class B(A):
def __init__(self):
super(B, self).__init__()
class C(B):
def __init__(self):
super(C, self).__init__()
b = B()
c = C()
print( b.name )
print( c.name )
>>>> B
>>>> C
