Not a direct answer to your question, but here are some helpful snippets.
Get the deformers from your objects:
from maya import cmds
for node in cmds.ls(sl=True):
deformers = cmds.findDeformers(node)
print(deformers)
OR
There’s also deformableShape you can use:
print(cmds.deformableShape(node, ch=True))
Get all geometry shapes being deformed by the deformers
for deformer in cmds.findDeformers(node):
print(deformer)
print(cmds.deformer(deformer, query=True, geometry=True))
Maya 2020 Query components MObject from component tags using maya.api.OpenMaya
The components tags are accessible in the API using MFnGeometryData and its new methods.
This uses MFnGeometryData from a shape’s local output attribute to query the components relevant to a tag.
import maya.api.OpenMaya as om
def get_mesh_components_from_tag_expression(geo, tag):
# Get the geo out attribute for the shape
out_attr = cmds.deformableShape(geo, localShapeOutAttr=True)[0]
# Get the output geometry data as MObject
sel = om.MSelectionList()
sel.add(geo)
dep = sel.getDependNode(0)
fn_dep = om.MFnDependencyNode(dep)
plug = fn_dep.findPlug(out_attr, True)
obj = plug.asMObject()
# Use the MFnGeometryData class to query the components for a tag expression
fn_geodata = om.MFnGeometryData(obj)
# Components MObject
components = fn_geodata.resolveComponentTagExpression(tag)
fn_components = om.MFnComponent(components)
# Whether the tag resolves to no components at all (is empty)
print(fn_components.isEmpty)
# Number of components
print(fn_components.elementCount)
# Do with the components what you need through the Maya API...
# e.g. reference: http://ewertb.mayasound.com/api/api.025.php
# etc.
return components
tag = "back"
for mesh in cmds.ls(type="mesh", noIntermediate=True):
print(mesh)
components = get_mesh_components_from_tag_expression(geo=mesh, tag=tag)
print(components)
The above example code uses the tag back which by default gets created on cubes in Maya 2022. So, e.g. make a cube and running this should show some output.
Maya 2020 Query components from component tags used in deformer using maya.cmds
With maya.cmds however here’s how to get the components for each geometry the deformer is influencing when using component tags.
def get_input(attr):
# Make sure shapes=True otherwise transform name is returned
inputs = cmds.listConnections(attr, source=True, shapes=True) or []
return next(iter(inputs), None)
for deformer in cmds.ls(type="geometryFilter"):
print(deformer)
num_inputs = cmds.getAttr(deformer + ".input", size=True)
for i in range(num_inputs):
plug = "{}.input[{}]".format(deformer, i)
geo = get_input(plug + ".inputGeometry")
tag = cmds.getAttr(plug + ".componentTagExpression")
print("Geo: %s Tag: %s" % (geo, tag))
print(out_attr)
# Get the geo components from the tag expression
components = cmds.geometryAttrInfo("{}.{}".format(geo, out_attr), componentTagExpression=tag, components=True)
print(components)
# Get the full components name (node + components)
mesh_components = ["{geo}.{component}".format(geo=geo, component=component) for component in components]
print(mesh_components)
Quickly thrown together as a prototype. It uses the new geometryAttrInfo command which allows you to query the components for a mesh based on the component tags in Maya 2022.
