Maxscript interacts with WPF
I used WPF to write an interface that implements the function of buttons to switch between different pages, and usercontrol for subpages. When calling this wpf-written interface library in MaxScript, the events are written in MaxScript. Events are useful when the widgets on my main page are bound in MaxScript. But the controls I defined in the subpage have no effect. But when I define Form1.MainContent.Content = Form2 – set the subpage as the main content
The subpage’s controls are also reactive when I first start, when I switch pages. Is there a response to the button event of the subpage, what is the reason, and how to solve it
This is the code for the main page
<Window
    x:Class="页面切换测试.MainWindow"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
    xmlns:local="clr-namespace:页面切换测试"
    xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
    Title="MainWindow"
    Width="250"
    Height="60"
    MinHeight="60"
    MaxHeight="1500"
    ResizeMode="NoResize"
    SizeChanged="MainWindow_SizeChanged"
    SizeToContent="Height"
    mc:Ignorable="d">
    <!--  SizeToContent="Height"  -->
    <Grid>
        <!--  使用 Grid 布局,定义两行:第一行用于按钮,第二行用于内容  -->
        <Grid.RowDefinitions>
            <RowDefinition Height="Auto" />
            <!--  第一行高度自动调整  -->
            <RowDefinition Height="*" />
            <!--  第二行占据剩余空间  -->
        </Grid.RowDefinitions>
        <!--  Buttons to switch between UserControls  -->
        <StackPanel
            Margin="10"
            HorizontalAlignment="Center"
            VerticalAlignment="Top"
            Orientation="Horizontal">
            <Button
                Width="100"
                Click="Button_Click"
                Content="Page 1" />
            <Button
                Width="100"
                Content="Page 2" />
            <Button
                x:Name="btn1"
                Width="auto"
                x:FieldModifier="public"
                Content="测试" />
            <!--  Add more buttons for additional pages as needed  -->
        </StackPanel>
        <!--  内容区域  -->
        <ContentControl
            x:Name="MainContent"
            Grid.Row="1"
            MinHeight="{Binding ElementName=MainWindow, Path=MinHeight}"
            MaxHeight="{Binding ElementName=MainWindow, Path=MaxHeight}"
            Margin="10"
            HorizontalAlignment="Stretch"
            VerticalAlignment="Stretch"
            x:FieldModifier="public" />
    </Grid>
</Window>
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
namespace 页面切换测试
    /// <summary>
    /// MainWindow.xaml 的交互逻辑
    /// </summary>
    public partial class MainWindow : Window
        private UserControl currentPage;
      private Dictionary<string, UserControl> pageCache = new Dictionary<string, UserControl>();
        public MainWindow()
            InitializeComponent();
            SwitchToPage("Page 1");
        public void Button_Click(object sender, RoutedEventArgs e)
            Button btn = (Button)sender;
            switch (btn.Content.ToString())
                case "Page 1":
                    break;
                case "Page 2":
                    SwitchToPage("Page 2");
                    break;
                    // Add cases for additional pages as needed
        public void SwitchToPage(string pageName)
            if (!pageCache.ContainsKey(pageName))
                switch (pageName)
                    case "Page 1":
                        pageCache[pageName] = new Page1();
                        break;
                    case "Page 2":
                        pageCache[pageName] = new Page2();
                        break;
            // 强制重新计算布局
          //  MainContent.InvalidateArrange();
          //  MainContent.InvalidateMeasure();
            // 订阅 SizeChanged 事件,确保在窗口大小变化时调整高度
            // this.SizeChanged += MainWindow_SizeChanged;
            // 调整窗口高度
            AdjustWindowHeight();
            currentPage = pageCache[pageName];
            MainContent.Content = currentPage;
            //AttachEventHandlers(currentPage);
        //private void AttachEventHandlers(UserControl page)
        //    // 解除之前的事件绑定
        //    var oldButton = currentPage?.FindName("siyou") as Button;
        //    if (oldButton != null)
        //        oldButton.Click -= HandleButtonClick;
        //    // 绑定新的事件处理程序
        //    var newButton = page.FindName("siyou") as Button;
        //    if (newButton != null)
        //        newButton.Click += HandleButtonClick;
        //private void MainContent_LayoutUpdated(object sender, EventArgs e)
        //    // 取消订阅 LayoutUpdated 事件,避免多次触发
        //    MainContent.LayoutUpdated -= MainContent_LayoutUpdated;
        //    // 调整窗口高度
        //    AdjustWindowHeight();
        private void AdjustWindowHeight()
            double minHeight = this.MinHeight;
            double maxHeight = this.MaxHeight;
            // 使用 Dispatcher 延迟调整窗口高度,确保 ActualHeight 已经计算完成
            this.Dispatcher.BeginInvoke(new Action(() =>
                double contentHeight = MainContent.ActualHeight;
              //  System.Diagnostics.Debug.WriteLine($"ContentHeight: {contentHeight}");
                if (contentHeight > 0 && contentHeight < maxHeight)
                    this.Height = Math.Max(contentHeight + 50, minHeight); // 确保高度不低于 MinHeight
                else if (contentHeight >= maxHeight)
                    // 如果内容高度超过最大高度,保持窗口高度为最大值
                    this.Height = maxHeight;
                else
                    // 如果内容高度小于最小高度,保持窗口高度为最小值
                    this.Height = minHeight;
            }), System.Windows.Threading.DispatcherPriority.Render);
        private void MainWindow_SizeChanged(object sender, SizeChangedEventArgs e)
           // this.SizeToContent = SizeToContent.Manual;
这是子页面的界面和事件代码
<UserControl
    x:Class="页面切换测试.Page1"
    d:DesignHeight="250"
    d:DesignWidth="250"
    mc:Ignorable="d">
    <Grid>
        <Button
            x:Name="siyou"
            VerticalAlignment="Center"
            Content="这是墙体页面"
            FontSize="24" />
    </Grid>
</UserControl>
using System;
using System.Linq;
using System.Text;
//using ManagedServices;
namespace 页面切换测试
    /// <summary>
    /// Page1.xaml 的交互逻辑
    /// </summary>
    public partial class Page1 : UserControl
        public Page1()
        //private void siyou_Click(object sender, RoutedEventArgs e)
        //    ManagedServices.MaxscriptSDK.ExecuteMaxscriptCommand("print \"Hello from MaxScript!\"")
这里是maxscript调用wpf程序的代码
fn main =
    -- 加载程序集
    dotnet.loadAssembly (getFilenamePath (getSourceFileName()) + @"页面切换测试.dll")
    global Form1 = dotnetObject "页面切换测试.MainWindow"
    global Form2 = dotnetObject "页面切换测试.Page1" -- 子页面对象
		  -- 切换到子页面
   -- local mainContent = Form1.FindName "MainContent"
	Form1.MainContent.Content = Form2 -- 设置子页面为主内容
	 dataContext = Form1.DataContext
    Form1.Show()
    (dotnetobject "System.Windows.Interop.WindowInteropHelper" Form1).Owner = dotnetobject "IntPtr" (windows.GetMAXHWND())
fn handleButtonClick sender args =
    -- 处理子页面按钮点击事件
    messageBox "子页面按钮被点击!"
fn handleButtonClick1 sender args =
    -- 处理主页面按钮点击事件
    messageBox "主页面按钮被点击!"
-- 	fn startFocus arg =
-- 		enableAccelerators = false
-- 	fn stopFocus arg =
-- 		enableAccelerators = true
fn setupEventHandlers =
    -- 主页面按钮事件绑定
   -- local button1 = Form1.FindName "btn1"
--     if button1 != undefined do
        dotNet.addEventHandler Form1.btn1 "Click" handleButtonClick1
--     else
--         print "Main button not found!"
    -- 子页面按钮事件绑定
  --  local button = Form2.FindName "siyou"
        dotNet.addEventHandler Form2.siyou "Click" handleButtonClick
		dotNet.addEventHandler Form1 "GotFocus" startFocus
		dotNet.addEventHandler Form1 "LostFocus" stopFocus
--     else
--         print "Child button not found!"
    -- 设置生命周期控制
 --   dotNet.setLifetimeControl button #dotNet
 dotNet.setLifetimeControl Form2.siyou #dotNet
	dotNet.setLifetimeControl Form1 #dotNet
    dotNet.setLifetimeControl Form2 #dotNet
main()
setupEventHandlers()
