Hi! I’m learning maxscript and having some problems with arrays. I believe I made this work at least once but now it’s not working so, I guess I accidentally broke it ![]()
This was supposed to give the vertex number of the selected vertex which is stored in the 2nd value of the array:
vert_sel_init = #{}
vert_sel_init = polyop.getVertSelection$
vert_sel_init[2]
I create a box, convert to editable poly and select two vertices manually. When I execute only the three lines above, I get this output:
#{1, 3}
false
What am I doing wrong?
Thanks for looking!
Problem solved.
