I am constantly being thrown of by the number values displayed in these various editors, such as the attribute editor, channel editor, command options window, and so on.
What are these number values relative to anyways? For example with the command Merge command (Edit Mesh > Merge), the threshold parameter, does a value of 1 correspond to 1 maya unit, and 0.5 is half of a Maya unit?
For example, past hour I have been trying to get a understanding for the threhold value of the merge command. I created a plane, scaled up by 10 uniformly, and then removed a edge loop, which means that some of its quads are 1cm by 1cm (squares), and others are 1cm by 2cm. When I select a mix of points that are distanced by 1cm or 2cm from one another and merge with a threshold of 0.5, all points are merged into one.
This is unexpected to me and completely confuses me. Doesn’t the merge command essentially mean “of the selected points, merge any vertices that have a distance of 0.5 cm or less to its neighbour”? So in my test, when I provided a value of 0.5 and “always merge for two vertices” unticked, I was expecting nothing to happen, since all vertices have a distance of 1cm or more between them.
Am on Maya 2025, my maya units are set Centimetres (the maya default),
Any help would be greatly appreciated!
