I am trying to write a simple function where I can toggle tweak mode (on/off) for all the transform tools at once. I can set tweak mode for one of the transform tools, manipMoveContext -e -tweakMode 1 moveSuperContext;, but if I switch to another tool, it will not be on. So I am trying to create a solution where, it will be to turned it on for all three tools, so that they stay in sync.
More or less I came up with the following:
string $currentCtx1 = `currentCtx`;
if ($currentCtx1 == "moveSuperContext"){
string $state = !`manipMoveContext -q -tweakMode moveSuperContext`;
}else if($currentCtx1 == "RotateSuperContext"){
int $state = (!`manipScaleContext -q -tweakMode scaleSuperContext`);
}else if($currentCtx1 == "scaleSuperContext"){
int $state = (!`manipRotateContext -q -tweakMode RotateSuperContext`);
if ($state == 1){
manipScaleContext -e -tweakMode 1 scaleSuperContext;
manipRotateContext -e -tweakMode 1 RotateSuperContext;
}else{
manipMoveContext -e -tweakMode 0 moveSuperContext;
manipScaleContext -e -tweakMode 0 scaleSuperContext;
manipRotateContext -e -tweakMode 0 RotateSuperContext;
But there are is a issue I cant find a way around; the rotate and scale tools tweakmode state cannot be queried if these tools are not active, this is unlike the move tool, whose state I can query, even if its inactive. I get the following error when I tried to query inactive scale/rotate tools:
this does not solve the issue: // Error: manipRotateContext: Object 'rotateSuperContext' not found.
searching around I have not found anything useful and ChatGPT is just leading me around in circles at this point.
How does one query the state of scale/rotate tools when they are inactive??
I am certain this is a very inefficient way to go about doing this sort of task, if someone knows of a “proper” or better way to do it I would love to know for sure. Thank you.
