Hi everyone, Is there any command or method to prevent the Maya Outliner from refreshing?
I found that using cmds.refresh(suspend=True) only locks the 3D viewport updates.
In my UI, I’ve designed a progress bar that calculates progress based on the number of tasks,
and during the process I call QtWidgets.QApplication.processEvents() to refresh the progress bar UI.
However, this also causes Maya’s viewport and UI to update frequently.
While cmds.refresh(suspend=True) works well to freeze the 3D viewport,
it doesn’t seem to stop the Outliner from constantly refreshing
This is how i disable/enable everything for one of my tools, it works for me as i recall made things faster:
def disable_all_panControl(self, enabled=True ):
Disable or Enable all modelPanel controls.
all_mp= cmds.getPanel(allPanels= True) # disable all panels, the hypershade ball panel was problematic
for p in all_mp:
if p != "scriptEditorPanel1": # skip scripteditor in case of errors.
try:
cmds.control(p, edit=True, visible= enabled, en= enabled)
except:continue
