How to calculate the blue channel for normal map?
It sounds like you may have gotten the use of the normals and the storage of the normals mixed together. Although the shader will remap the texels in your map from 0-1 RGB values to -1 > 1 vector components, that’s a matter for interpretation; when actually reading the textures your values are just 0-1. So you probably don’t want to use 2x -1 / 2y-1 to calculate the z, your want to calculate your normalized pixel from the 0-1 values in the raw texture.
If you use pre-normalized maps:
  1. The normal maps need to be stored in a linear format without gamma correction.
  2. The original normals were normalized before the blue component was removed
If both of those are true, B is just sqrt(1 - (sqrt® + sqrt(G))). So, for example, a pixel with a straight up normal would be (.5, .5, .707) in the original, then stored as (.5, .5) and reconstructed as sqrt (1 - (.25 + .25) ) or sqrt (.5) which is .707
If your normal maps are NOT prenormalized, you won’t be able to reconstruct the blue channel – you’d have to store it explicitly some how.
