This is something I have been trying to determine but have so far not had any luck.
Looking at the dagMenuProc.mel (C:\Program Files\Autodesk\Maya2026\scripts\others), which the script for the right click marking menu, I learned that maya does not determine the object under the mouse in that file.
I observed through the script editor, Maya actually calls a procedure in that file and passes the name of the object under the mouse as an argument:
mayaUsdMenu_markingMenuCallback "<objectName>";
//for example;
mayaUsdMenu_markingMenuCallback "pCylinder3";
This has just confused me even further, what is firing this event? searching around some more, just before maya calls the above mel line, it calls this line:
buildObjectMenuItemsNow "MainPane|viewPanes|modelPanel4|modelPanel4|modelPanel4|modelPanel4ObjectPop";
Reading the code forbuildObjectMenuItemsNow, it does have some ls calls in it but testing them out in isolation does not give me what I was expecting. The following lines is what I got from buildObjectMenuItemsNow scrip file but no object names are returned, under mouse pointer or even selecton:
ls -sl -tail 1 -typ transform -typ shape;
ls -hl -tail 1 -typ transform -typ shape;
ls -sl -ufe -long -tail 1 -typ transform -typ shape;
With the above examples, I am using Mel because of Maya’s source files being in Mel.
I intend to write my solution in Python, also I am open to any solution that involves the Maya API.
I would appreciate any help or insight into where am going wrong.
maya uses an internal command to find thisdata which is a raycast from the camera to the mouse and takes the first object it finds
i created a hacky setup for this before which you can use to get the same information:
from maya import OpenMaya as OldOpenMaya, OpenMayaUI as OldOpenMayaUI
from PySide6.QtGui import QCursor
from PySide6.QtWidgets import QApplication
def objectUnderMouse(margin=4):
def selectFromScreenApi(x, y, x_rect=None, y_rect=None):
sel = OldOpenMaya.MSelectionList()
OldOpenMaya.MGlobal.getActiveSelectionList(sel)
if None not in (x_rect, y_rect):
OldOpenMaya.MGlobal.selectFromScreen(x, y, x_rect, y_rect, OldOpenMaya.MGlobal.kReplaceList)
else:
OldOpenMaya.MGlobal.selectFromScreen(x, y, OldOpenMaya.MGlobal.kReplaceList)
objects = OldOpenMaya.MSelectionList()
OldOpenMaya.MGlobal.getActiveSelectionList(objects)
OldOpenMaya.MGlobal.setActiveSelectionList(sel, OldOpenMaya.MGlobal.kReplaceList)
fromScreen = []
objects.getSelectionStrings(fromScreen)
return fromScreen
active_view = OldOpenMayaUI.M3dView.active3dView()
pos = QCursor.pos()
widget = QApplication.widgetAt(pos)
relPos = widget.mapFromGlobal(pos)
foundObjects = selectFromScreenApi(relPos.x() - margin,
active_view.portHeight() - relPos.y() - margin,
relPos.x() + margin,
active_view.portHeight() - relPos.y() + margin)
return foundObjects
hope this helps
This works really well, on all objects, thank you for sharing this.
For whoever might stumble upon this thread in the future, I would also like to share this solution I found yesterday, but unlike the above solution, it does not fully work, that is will identify most objects under the mouse pointer accept for curves.
Maya-Python getting shape under cursor
def object_under_cursor():
"""Get objects under cursor"""
pos = QtGui.QCursor.pos()
widget = QtGui.qApp.widgetAt(pos)
relpos = widget.mapFromGlobal(pos)
panel = cmds.getPanel(underPointer=True) or ""
if not "modelPanel" in panel:
return
return (cmds.hitTest(panel, relpos.x(), relpos.y()) or [None])[0]
