Feedback Maxscript
I made my first ‘not so big’ maxscript.
It would be great if you could give me some feedback on what could be better or things I have to keep in mind.
The function of this maxscript is loading the necessary tga’s into the right maps. It depends on the filename of a 1pxtga whether it updates or not and whitch maps.
Just a note. This maxscript is just a part of the application. There is also a javascript that saves the right tga’s out of one psd. Normalle the psd would be loaded in the maxscript, but that did not worked. Still have to found out.
It was supposed to be a realtime application so you could edit your textures in photoshop and directly see them in max. But it looks like it is not possible to run a script while working in photoshop. So now it is a action tha calls a script.
Thanks for your time.
rollout PMI "PMI" width:232 height:248
	mapButton btn_File "Load PsdFile" pos:[16,24] width:200 height:24 toolTip:"Loads the Info FileTga"
	groupBox grp_File "File" pos:[8,4] width:216 height:52
	groupBox grp_LoadedMaps "Loaded Maps" pos:[8,64] width:216 height:152
	editText info_diffuse "" pos:[16,88] width:200 height:24
	editText info_normal "" pos:[16,120] width:200 height:24
	editText info_specular "" pos:[16,152] width:200 height:24
	editText info_opacity "" pos:[16,184] width:200 height:24
	--Vars-----------------------------------------------------------------------
	local Rollout_RealtimeTimerE
	timer clock "testClock" interval:333  active:false
	local PSDName = ""
	local FileName = ""
	local FileNamePath = ""
	local InfoCodePart = ""
	local Ref_Texmap = ""
	--Events--------------------------------------------------------------------
	on PMI open do
		info_diffuse.readOnly = true
		info_normal.readOnly = true
		info_specular.readOnly = true
		info_opacity.readOnly = true
		info_diffuse.text = "[-] - Diffuse"
		info_normal.text = "[-] - Normal"
		info_specular.text = "[-] - Specular"
		info_opacity.text = "[-] - Opacity"
	-- Closing the timer when shutting down
	on PMI close do
		print "closed"
	on btn_File picked texmap do
		Ref_Texmap = texmap
		PSDName = getFileNameFile (texmap.filename)
		local FilePath = texmap.filename
		FileNamePath = getFilenamePath FilePath
		local TgaFiles = getFiles (FileNamePath +  "*.tga")
		for f in TgaFiles do
			FileName = getFilenameFile f
			local Arr_PartsFileName = filterstring FileName "_"
			local CountParts = Arr_PartsFileName.count
			if CountParts == 1 then
				--Do Nothing otherwise there will ba an error
				-- there is no O index
			else
				local CodePart = Arr_PartsFileName[CountParts-1]
				local UpdatePart = Arr_PartsFileName[CountParts]
				if CodePart.count == 8 and UpdatePart == "1" do
					clock.active = true
					InfoCodePart = CodePart
				if CodePart.count == 8 and UpdatePart == "0" do
					clock.active = false
	on clock tick do
			if(InfoCodePart[2] == "1") do
				meditMaterials[1].diffuseMapEnable = on
				meditMaterials[1].diffuseMap = Bitmaptexture fileName:(FileNamePath + PSDName + "_D.tga")
				info_diffuse.text = "[+] - Diffuse"
			if(InfoCodePart[4] == "1") do
				meditMaterials[1].bumpMapEnable = on
				meditMaterials[1].bumpMap = Normal_Bump ()
				meditMaterials[1].bumpMap.normal_map = Bitmaptexture fileName:(FileNamePath + PSDName + "_N.tga")
				meditMaterials[1].bumpMapAmount = 100
				info_normal.text = "[+] - Normal"
			if(InfoCodePart[6] == "1") do
				meditMaterials[1].specularMapEnable = on
				meditMaterials[1].specularMap = Bitmaptexture fileName:(FileNamePath + PSDName + "_S.tga")
				info_specular.text = "[+] - Specular"
			if(InfoCodePart[8] == "1") do
				meditMaterials[1].opacityMapEnable = on
				meditMaterials[1].opacityMap = Bitmaptexture fileName:(FileNamePath + PSDName + "_O.tga")
				info_opacity.text = "[+] - Opacity"
			stringedoe = FileNamePath  +  PSDName + "_" + InfoCodePart + "_0.tga"
			renameFile Ref_Texmap.filename stringedoe
createDialog PMI
I am getting this error when opening the app - loading the psd - closing the app - reopening the app -reloading the psd - error
If i then press view bitmap in my material editor to view the (for example) diffuse bitmap then i get the same error.
Someone has an idea?
