Dockable PySide widgets in Maya Dock Windows
This function allows you to dock PySide Gui’s into a dockable window in Maya. It’s fairly straightforwards to use.
Credit goes to Jeroen Heemskerk who came to my rescue when I was searching for an easy way to dock existing ui’s without having to add more to them.
# import whichever pyside you need
from PySide2 import QtWidgets
# from PySide6 import QtWidgets
try:
    import shiboken2 as shib
except ImportError:
    try:
        import shiboken6 as shib
    except:
        print("COULDN'T IMPORT SHIBOKEN!")
from maya import OpenMayaUI as omui
def create_dockable_window(widget, title: str):
    """Creates a dockable Window"""
    workspace_control_name = widget.objectName() + "_WorkspaceControl"
    if cmds.workspaceControl(workspace_control_name, q=True, exists=True):
        cmds.deleteUI(workspace_control_name)
    # Create the dock with Maya's workspace control system
    control = cmds.workspaceControl(
        label=title,
        floating=True,
        resizeHeight=500,
        resizeWidth=500,
        # ttc=["AttributeEditor", -1],  # Target tab (optional, removes float behavior)
        # retain=True,  # <-- makes it persistent across sessions
        # uiScript="import MyModule; MyModule.MyFunction()"
    # Parent the widget under the workspace control
    control_ptr = omui.MQtUtil.findControl(workspace_control_name)
    control_widget = shib.wrapInstance(int(control_ptr), QtWidgets.QWidget)
    layout = control_widget.layout()
    if layout is not None:
        layout.addWidget(widget)
# Assuming you have a tool that has a ui object
# In theory this should also work if your business logic is also in your gui - just pass in whatever pyside widget you want docked
import your_tool
tool = your_tool.Tool()
create_dockable_window(tool.ui, "MyTool")
Why not just make your dialog subclass from PySide2.QtWidgets.QDockWidget?
Or maya.app.general.mayaMixin.MayaQDockWidget?
It may be worth comparing/contrasting these different techniques for future google hits.
Mainly because I wanted to not adjust our existing tools just for docking.
This lets me just add our existing UI to a widget and I don’t need to go back in and adjust things :slight_smile:
A lot of the tools we have shouldn’t be dockable but some are fine, but I generally avoid docking as I’ve had to clean up other people’s tools that caused me lots of issues…and it made me sad
