Arnold MaterialX to UE5 Converter — free Python script
Hey everyone,
I’ve been trying to use Maya’s arnoldToMaterialX command to bring Arnold materials into UE5 (Substrate), and ran into a wall: the exported .mtlx files simply won’t import. UE5’s Interchange importer throws errors like:
  • has no matching NodeDef
  • Mismatched types in port connection
  • There was no data to import
After digging into the MaterialX spec and UE5’s importer behavior, I built a Python conversion script that fixes all of these issues automatically.
What it does
Arnold’s exporter produces non-standard constructs that UE5 doesn’t understand. The script converts them:
Structural fixes
  • Removes xi:include / xmlns:xi declarations
  • Fixes standard_surface type="closure"type="surfaceshader"
  • Sanitizes node names containing / or .
Arnold node normalization
  • aiColorCorrect → expanded into power + mix(luminance) + subtract/multiply/add
  • aiNormalMap / normal_mapnormalmap
  • aiMultiply, aiAdd, aiMix, aiClamp, aiPow → standard equivalents
  • Input names normalized (input1/input2in1/in2, etc.)
Image node fixes
  • filename input → file (type filename)
  • color_space input → colorspace attribute
  • type="color4"color3 / float / vector3 as needed
  • Grayscale channels (channels="r") → image type="float" direct connection
  • Arnold-only inputs removed (ignore_missing_textures, etc.)
uv_transform expansion
  • Replaced with texcoord + multiply
  • Maya repeat=2 correctly maps to UV multiply by 2 (Note: UE5’s place2d scale works in the opposite direction — took a while to figure out)
Colorspace mapping
  • sRGB Encoded Rec.709 (sRGB)srgb_texture
  • Raw / Linearlin_rec709
  • ACEScgacescg
Unsupported node passthrough
  • Any node UE5 doesn’t support is automatically bypassed
  • Downstream connections are rewired to keep the network intact
  • Chains of unsupported nodes are resolved iteratively
Usage
bash
python arnold_mtlx_to_ue5.py input.mtlx output.mtlx
Python 3.8+, no dependencies.
Known limitations
  • hue_shift in color_correct is not converted (no hue-rotation node in UE5’s standard library)
  • uv_transform rotation is not supported (only repeat/offset)
  • Unsupported nodes are bypassed — visual result may differ from Arnold
Tested with
  • Maya 2026 + Arnold 7.x
  • Unreal Engine 5.7.3 (Substrate + Interchange)
  • MaterialX 1.39
GitHub: https://github.com/c-Carter-z/arnold-materialx-to-ue5
To my knowledge there’s no other public tool that handles this conversion end-to-end. Hope it helps. Feedback and PRs are welcome.
— C.Carter
