Why logger.info('xxx') doesn't print message to maya script editor?
Hi , I want to use logging module in my script (in maya script editor) , but why this doesn’t work ?
import logging
logger = logging.getLogger('myLogger')
logger.setLevel(logging.INFO)
# the this should print out something right ?
logger.info('oh yeah this is something!')
Am I missing something ?
edit: I tried this, but unfortunately it doesn’t work either, only warn/error/critical show up.
import logging
logger = logging.getLogger('simple_example')
logger.setLevel(logging.DEBUG)
ch = logging.StreamHandler()
ch.setLevel(logging.DEBUG)
# create formatter
formatter = logging.Formatter('%(asctime)s - %(name)s - %(levelname)s - %(message)s')
ch.setFormatter(formatter)
logger.addHandler(ch)
# prevent logging from bubbling up to maya's logger
logger.propagate=0
# application' code
logger.debug('debug message')
logger.info('info message')
logger.warn('warn message')
logger.error('error message')
logger.critical('critical message')
edit2: I know why now, in another module, there is some code disabled logging globally. after I run
logging.disable(logging.NOTSET)
logger.info and logger.debug start working
this helps “reenable” your temporarily disabled logger:
import logging
class DisableLogger():
    def __enter__(self):
       logging.disable(logging.CRITICAL)
    def __exit__(self, a, b, c):
# Example of use:
with DisableLogger():
    do_something()
import logging
logging.basicConfig()
logger = logging.getLogger('foo')
logger.info('dadsa')
a better solution for bigger libs is to use 15.8. logging.config — Logging configuration — Python 2.7.18 documentation
