For a python function without a return statement, the function result is returned to the
function object that called it ???
Whats the difference between that and the return statement ?
All Python functions have a return. If you don’t specify a return explicitly , it’ll return None.
Understood, but what about the python example below, curious for your thoughts:
def simpleMath(a,b,c):
sum = a + b + c
simpleMath(1,2,3)
print(sum) # 6 is returned to the variable sum outside of the function, doesn’t that go
# against the scope rules, or is that considered the return ?
Are you sure your code doesn’t have some dirty variables you set earlier?
Run it in a clean session. You should either see that sum is a built in function when you print , or if you change the variable name, a name error because your variable doesn’t exist.
The only way something would leak out is
A) you have a faulty Python interpreter (highly unlikely)
B) you used the global keyword and then set it inside your function (generally bad code)
C) your actual code is passing a mutable object in like a list and you’re observing a mutation of an object. (But your code snippet here is non mutating)
You can see that Python doesn’t escape the scope here
I suspect your real example is running in a dirty session or something else is afoot.
Thanks for the info, very cool online python compiler.
You were totally right… dirty variable. I was wondering what was going on.
