Here’s a class that lets you watch a directory on a separate thread. It makes use of the ReadDirectoryChanges API, as mentioned above.
import types
import threading
import win32file
import win32con
import os
class WatchDirectory(object):
This method was adapted from example by Tim Golden:
http://tgolden.sc.sabren.com/python/win32_how_do_i/watch_directory_for_changes.html
Watches for changes to any file/dir inside specified directory.
Instantiating this class spawns the watcher function in a separate thread.
self.changeList accumulates changes until client requests list using the check() method.
Calling that method returns the changeList then empties it.
The watching thread will self-terminate when the WatchDirectory instance is destroyed
or falls out-of-scope.
Usage Examples:
watcher = WatchDirectory(r'D:\myStuff')
# Typically you'd have a main loop here somewhere, inside of which you'd make occasional
# calls to watcher.check, like so:
while (not doneWithLoop):
changes = watcher.check()
for c in changes:
# do something to each modified file, etc...
print "file: %s, change: %s" % c
See self.ACTIONS below for a list of possible change strings.
Also, the "onlyExtensions" keyword arg can be used to only watch certain filetypes:
watcher = WatchDirectory(r'D:\myStuff', onlyExtensions=('.jpg', '.xml')
NOTES:
ChangeList returned is chronological, oldest to newest. A file that's modified early in the list
could show up as deleted later. Your client code is responsible for verifying files still
exist, etc.
The win32 method used here seems very reliable. I did notice that it fails to report
deleted files if they were inside a subdir that was deleted in its entirety, however.
Seems like a border case, however, so I'm inclined to leave it as-is for now.
Also, deleted subdirs still sometimes show up as a change with watchSubdirs=False.
TODO:
- Maybe add option to not multithread, making it a blocking call.
Adam Pletcher
adam@volition-inc.com
Volition, Inc./THQ
def __init__(self, dirToWatch, bufferSize=1024, watchSubdirs=True, onlyExtensions=None):
self.dirToWatch = dirToWatch
self.changeList = []
self.bufferSize = bufferSize
self.watchSubdirs = watchSubdirs
if (type(onlyExtensions) == types.StringType):
onlyExtensions = onlyExtensions.split(',')
self.onlyExtensions = onlyExtensions
# Constants for making win32file stuff readable
self.ACTIONS = {
1 : "Created",
2 : "Deleted",
3 : "Modified",
4 : 'Renamed to something',
5 : 'Renamed from "%s"'
# Start watching in a separate thread
self.thread = threading.Thread(target=self._checkInThread).start()
def _checkInThread(self):
Watch for changes in specified directory. Designed to be run in a
separate thread, since ReadDirectoryChangesW is a blocking call.
Don't call this directly.
while (1):
FILE_LIST_DIRECTORY = 0x0001
hDir = win32file.CreateFile (
self.dirToWatch,
FILE_LIST_DIRECTORY,
win32con.FILE_SHARE_READ | win32con.FILE_SHARE_WRITE,
None,
win32con.OPEN_EXISTING,
win32con.FILE_FLAG_BACKUP_SEMANTICS,
None
# The following is a blocking call. Which is why we run this in its own thread.
newChanges = win32file.ReadDirectoryChangesW (
hDir, # Previous handle to directory
self.bufferSize, # Buffer to hold results
self.watchSubdirs, # Watch subdirs?
win32con.FILE_NOTIFY_CHANGE_FILE_NAME | # What to watch for
win32con.FILE_NOTIFY_CHANGE_DIR_NAME |
win32con.FILE_NOTIFY_CHANGE_ATTRIBUTES |
win32con.FILE_NOTIFY_CHANGE_SIZE |
win32con.FILE_NOTIFY_CHANGE_LAST_WRITE |
win32con.FILE_NOTIFY_CHANGE_SECURITY,
None,
None
# Changes found, process them
finalChanges = []
oldFilename = None
for change in newChanges:
if (change[0] == 4): # renamed to something
oldFilename = os.path.split(change[1])[1]
pass
else:
file = os.path.join(self.dirToWatch, change[1])
skip = False
# Verify a few things first
if (not self.watchSubdirs) and (os.path.isdir(file)):
skip = True
elif (self.onlyExtensions) and (not os.path.splitext(file)[1] in self.onlyExtensions):
skip = True
if (not skip): # passed checks, so use it
action = self.ACTIONS.get (change[0], "Unknown")
if (change[0] == 5): # renamed from something
# Insert old filename, prior to being renamed
action = action % (oldFilename)
oldFilename = None
# Add change tuple to list
finalChanges.append((file, action))
# Add processed changes to running list
self.changeList += finalChanges
def check(self):
Fetches list of changes our watcher thread has accumulated.
changes = self.changeList
self.changeList = [] # clear changeList
return changes
### MAIN ###
if (__name__ == '__main__'):
import time
watcher = WatchDirectory(r'D: emp\watchTest')
while (True):
for c in changes:
time.sleep(5) # wait 5 seconds before checking again
I’ll archive this on the Wiki, too. Seems like a good recipe to have around.
Edit: I added this to the TAO Wiki: Recipe: Watch Directory for Changes
