Hello all,
I am working on a tool for a tool set I am building in Maya and have ran into a small problem. I am running a few checks and decided to put them into separate functions and am losing my targeted variable and can not figure out why. Here is my code.
print("jointAdd.py Loaded")
win = "jointAdd"
selJoint = cmds.ls(sl=1)
selChild = cmds.select(selJoint, hi=1)
selChildP = cmds.ls(sl=1)
selChildFinal = selChildP[1]
def gui():
if(cmds.window(win, q=1, ex=1)):
cmds.deleteUI(win)
if(cmds.windowPref(win, q=1, ex=1)):
cmds.windowPref(win, r=1)
cmds.window(win, t=win, w=300, h=125)
cmds.columnLayout("baseCol")
cmds.intSliderGrp( cw3=[75, 50, 100], field=True, label='Joint Addition', minValue=0,
maxValue=15, fieldMinValue=0, fieldMaxValue=15, value=0 )
cmds.button( l="Add Joints", w=290, c="jointAdd.orientCheck()")
cmds.showWindow(win)
def orientCheck():
select -d joint1 ;
insertJoint joint1;
// Result: joint3 //
joint -e -co -p -1.52704e-018 0.942082 0 joint3;
insertJoint joint3;
// Result: joint4 //
joint -e -co -p -3.51219e-018 1.51679 0 joint4;
insertJoint joint4;
// Result: joint5 //
joint -e -co -p -5.28356e-018 2.02961 0 joint5;
#Check if the joints are oriented
if(cmds.getAttr(selChildFinal + ".tx") > 0) and (cmds.getAttr(selChildFinal + ".ty") > 0):
print("Joints are not oriented correctly")
elif(cmds.getAttr(selChildFinal + ".tx") > 0) and (cmds.getAttr(selChildFinal + ".tz") > 0):
elif(cmds.getAttr(selChildFinal + ".ty") > 0) and (cmds.getAttr(selChildFinal + ".tz") > 0):
else:
print("Joints are oriented!")
getAxis()
def getAxis():
#Figure out joint child axis
if(cmds.getAttr(selChildFinal + ".tx") > 0):
childAxis = ".tx"
elif(cmds.getAttr(selChildFinal + ".ty") > 0):
childAxis = ".ty"
elif(cmds.getAttr(selChildFinal + ".tz") > 0):
childAxis = ".tz"
else:
print("Child is too close to subdivide")
print(selChildFinal + " is oriented down the " + childAxis + " axis.")
I do not know where I am losing it but I get this error in maya:
# File "<maya console>", line 1, in <module>
# File "C:/Users/Carey/Documents/maya/scripts\jointAdd.py", line 50, in orientCheck
# def getAxis():
# File "C:/Users/Carey/Documents/maya/scripts\jointAdd.py", line 53, in getAxis
# childAxis = ".tx"
# TypeError: Object [] is invalid #
